Fastening Gap flasher for launch control
lakercr
Tech Advisor
Winnipeg, Manitoba
I finally got around to installing my Hurricane launch control cable. The flasher needs to be connected to the control cable for LC to function. I want to be able to remove it easily, but also have it secure for when in use. Doo makes a 180mm double-sided velcro strap for securing part of their electrical harness, and I had a spare one to try out. I put two slits in the plastic, fed the strap through, and then strapped the flasher down. Looks like it is going to work well - flasher is secure and it can be removed in just a few seconds when not in use.
Doo part # is 414115200
Doo part # is 414115200 View attachment 134191
FYI, when those flasher are plugged in and the key is on they will stay connected until they are unplugged, even after the key is pulled out. The light is still flashing.
No power when connected and using the anti lag harness. The other harness which connects down by the chain case has power all the time and can drain battery.
So why not provide the antilag harness in all cases if one is going to keep the flasher installed on the sled for quick map changes?
look at the gap system as modular....not everyone will have a flasher....some are just tuned ecu's....and then not everyone wants the anti lag...or data logging...then theres CoPi trail...etc etc...
Lakercr , I like your setup...just not thrilled with making the holes there ...but in the goggle bag...yes!
Mine is all apart again now, but last night when it was all connected the red LED was still blinking with ignition off/flasher plugged into the LC harness.
From my understanding is it will draw down the battery if its left on there flashing over a week. A day here and there wont kill it.
That would work nicely, but I'm not going to use the goggle bag...
My understanding as well. I'll put my meter on it before the seat goes back on and see if I can even get a reading for current draw. Regardless, I'm not worried about it.
Can you report back please? I would like to know how much they draw and if there is anything to really worry about.
Guys. Mine has been plugged in since June with the antilag harness. No lights on when key is off. and battery is fine no troubles.
the diagnostic plug by the chaincase is live...and yes draws power ...the anti lag harness connection is NOT live and should not remain lit....if you saw a red light after ignition off...there could be a issue with the harness or the flasher and you should contact Dave or Gap as it could be an algorithm issue
Same experience I've had - no draw at all if left in anti-lag harness. I haven't checked battery draw when connected at chain case, will try to this weekend.
It won’t kill the battery plugged into the antilag harness mine stays there 100% of the time between asphalt races this summer sometimes weeks and never a dead battery
