Is your light flashing with the key out?It won’t kill the battery plugged into the antilag harness mine stays there 100% of the time between asphalt races this summer sometimes weeks and never a dead battery
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
Guys, the original antilag harnesses turned off the ignition power to the flasher when the key was in the off position. I asked gap to change that to having the flasher powered up all the time because we were having to reset the data logging and phone connection through the day at the race track. It was a bit cumbersome. Now with the flasher powered up all the time that it’s plugged in, all settings and connections stay active until disconnected intentionally
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Good idea and good to know
Wont this draw the battery down in time?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
Over the span of a week or two yes. That why we recommend to remove the flasher between rides
Thats kind of the point I was getting at in the beginning. I wanted user to know that before they had a dead sled. Thank you for verifying that for me.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Hmmm, mine doesn'tMine is all apart again now, but last night when it was all connected the red LED was still blinking with ignition off/flasher plugged into the LC harness.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Looks like I’ll be installing a toggle switch In mine which wire do we have to move to make it powered all the time? I have the old harness?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Id like to know which wire as well is powered with key off on the anti lag harness. A switch inline would be an easy solution.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
- 11K
- 7K
- 10K
