Turboflash
- Mar 18, 2019
- Southern MN
You're gonna like it!!I just bought 21/38 to try!! I am going to run my 24/50 for 1000km then swap and see what I like better for trail riding
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
What length chain does 21/38 use? 84-link?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
YesWhat length chain does 21/38 use? 84-link?
DMCTurbo
- Nov 12, 2005
22/41 is good for 131-32 ish. I personally gps'd mine at 131.4 in 2000 feet.I decided not to go with my 24/50 so I have brand new from Cat 24T, 50T and 92 chain I need to get rid of if anyone is interested... In Canada is easier for shipping.
What's the difference in doing the 21/38 VS 22/41 for top speed and general trail riding?
21/38 is good for 135-36 ish
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
Ok so I will just do the 22/41,plenty for me.
Century21chad
- Sep 4, 2015
- Fort Frances, Ontario
- 2014 SR Viper
Thoughts on your 24-48 setup?I'm going to run the 24/48 next year which is only slightly lower than 21/41. Also have decided to try the ultimax belt instead of the 8dn in order to bring back top speed.
What chain did you need for the 24-48 gears?
I've got a 90 pitch chain and hoping this will work.
The chain from the 24/50 setup worked, but the adjusting bolt was at the end. If I remember correctly, I think I did switch to the next shorter chain which would be the 90.Thoughts on your 24-48 setup?
I like the setup so far.
This morning I was able to do a top speed pull and the machine GPS'd 124 with 24/48
That is moving by any bodies standard!
I used to run the same 2:1 ratio(20/40) way back when I was running the SRX 700 in A and B stock running high 80's in 500 feet. I'm thinking I was geared way too high.That is moving by any bodies standard!
If I didn't see it myself I'm not sure I'd believe a 2 ratio would achieve this speed.
Having said that, I was well into the 9's rpm
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
Are you tuned or stock?This morning I was able to do a top speed pull and the machine GPS'd 124 with 24/48
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
How was that at 1000 ft ,quicker than 21/41
That was 260hp, stock mufflerAre you tuned or stock?
Crossfire, I don't have the TD GPS timer tool, but its on my wish list.How was that at 1000 ft ,quicker than 21/41
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Dragy is much cheaper, just as accurate, and easier to use.
https://www.amazon.com/dragy-10Hz-B...r&qid=1580778910&sprefix=dragy,aps,430&sr=8-2
https://dragymotorsports.com/
