I am now officially done modding my Viper! No more.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Famous last words
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
for this week?I am now officially done modding my Viper! No more.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
not a chance a bone stock mach is going over 120,i owned two of them and they top out at 116 tops,my dreameter would show 125 thats it,i owned 2 machs back in the day!!THEN they blow up after a few attempts and i mean blow up bigtime!!!I was wondering who was gonna get out first on hardpack or road and wind one of these babies up!
Nice to hear! I think we finally have a stock factory 120+mph sled once again. Its been a long time since the day of those speeds out of the box(Mach z Ck3 im thinkin)
Dan
SWTURBO
- Mar 22, 2016
- Sidewinderturbo
That'll get the LSP crew talking lmao
newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
How far off is the speedo compared to the gps?
It was spinning. It was showing anywhere from 120 to 126
stone88
That was with no studs it will go faster with a few studs as the track will spin violently but it will tap out at 122/ 123 out of gear
newtron
- Jan 2, 2010
Well you could be right about tapping out at 123, but i'm thinking higher. It wasn't over revving when it was 125/126 on the speedo.
Here is pic of the primary. Still some overdrive to have I think.
stone88
Unfortunately that's as high as it goes on a stock primary you will need to machine it to go higher. If you look at the top there are black lines that showsyou are slipping. All in all you have to be happy
newtron
- Jan 2, 2010
Ok good to know. Off to the machine shop. hahah
This is a whole new Primary. Are you sure it needs to be machined already! Cripes give the guy a chance.Unfortunately that's as high as it goes on a stock primary you will need to machine it to go higher. If you look at the top there are black lines that showsyou are slipping. All in all you have to be happy
newtron
- Jan 2, 2010
Don't worry cannondale. I'm not touching the clutch. Sick of wrenching on my turbo viper last 2 years. Turbo, pistons, rods, head shim, Gearing, primary weights, springs, secondary helix, secondary spring, boost a/f gauges, blah blah blah blah. I have a turn key 120 mph sled with warranty.......done!!!!
Good! Has to really be a relief I bet.Don't worry cannondale. I'm not touching the clutch. Sick of wrenching on my turbo viper last 2 years. Turbo, pistons, rods, head shim, Gearing, primary weights, springs, secondary helix, secondary spring, boost a/f gauges, blah blah blah blah. I have a turn key 120 mph sled with warranty.......done!!!!
Pstn head
Heck you didn't mention machinening clutches on your Viper, it could of been a 120 mph machine if you did LOL !
newtron
- Jan 2, 2010
They are machined!! Its Fast
