mplourde
????Yes with cat
Envoyé de mon SM-G935W8 en utilisant Tapatalk
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
FWIW after looking at mine after 500 miles they are fine. I thought they looked like they were flat spotting after the first day but when I checked today all is good. Out of curiosity, the people with flat spotted ones, what is your secondary spring set at?
All rollers flat spotted, secondary came with spring at 40 degrees. Installing new rollers tomorrow and going to 60 degree wrap on spring and testing this weekend.
mplourde
Ok nobody tried that yet... I'm going in a trip on this week end. Should I take the guest to remplace it before or stay with oem flatted spot to be sure ?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
I get you haven't touched it. Some seem to be showing up with the secondary set up wrong. You need to look at what the spring is in helix then pull the helix and see where it is seated in the secondary. It should be 3-3 from the factory some are showing up 3-1. Mine was 6-1 when I got it. The dealer might have changed it though. I have a theory on the issue but I'm trying to find out what the ones with issues are set at.stock setting, never been touched, 112 miles
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
When I ran Doos, which didn't have the tortional spring in the secondary, I would shatter stock rollers all the time. When you would lock it up in a corner then slam back into the throttle it would pull the rollers away from the helix them smash them back into it. If our secondary's are coming with light settings I think this might be happening and denting the rollers. Once you dent them they just ride that spot and flat spot them. I don't see any other reason other than a supplier issue that can cause some people to be having the issue and others not.
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
i have the thunder kit coming so i will pull it next week.I get you haven't touched it. Some seem to be showing up with the secondary set up wrong. You need to look at what the spring is in helix then pull the helix and see where it is seated in the secondary. It should be 3-3 from the factory some are showing up 3-1. Mine was 6-1 when I got it. The dealer might have changed it though. I have a theory on the issue but I'm trying to find out what the ones with issues are set at.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Your XTX 137 was at 40? Haven't had the secondary off mine yet.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Yes at 40. 3 and 1. Using a good flashlight I could see the numbers on the sheave and which hole spring was in with the clutch installed.
mplourde
Mine is 6 and 1... stock from the dealer
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
There went that theory...Mine is 6 and 1... stock from the dealer
mplourde
I don't understand why so much difference in setting right from dealer.. mine is ltx
Pstn head
Can anything go wrong if riden with flat spots on the rollers ?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
Eventually you will wear through them and probably destroy they helix. The worst pic I saw was at 500 miles and had a while to go before that. I would think it would wear the helix a little unless the rollers are made from something softer than the helix.Can anything go wrong if riden with flat spots on the rollers ?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Secondary won't open all the way and can cause belt issues.
- Dec 6, 2016
- saegertown pa
just put the rollers in. forgot to bring them in for pic. didn't pull it apart, just off the sled. if you are looking at number by roller on sheave, it is spring in 3, above #1 roller. never did a clutch before. if i need to pull it apart i'll have to figure a way to hold the tension. still off the sled.
- 6K
