krm
- Apr 22, 2016
- ny
How many with flat spots still have the stk. ramps ? No flat spots on mine but i got rid of the stk.ramps first thing .
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Kenny this discussion is on secondary rollers. Spring tension doesn't seem to matter. Some folks are trying the expensive Cat rollers but I haven't heard any feedback as of yet?
Besides I thought you gave up on the Sidewinder? Isn't it parked for the season? Ha!
krm
- Apr 22, 2016
- ny
yes/no My driven rollers are good also .Kenny this discussion is on secondary rollers. Spring tension doesn't seem to matter. Some folks are trying the expensive Cat rollers but I haven't heard any feedback as of yet?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Do you guys think they will make a recall??? before april???
Most of hard riders on the french chat have flat spot! Except for me....lol
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
What I don't understand is did Yamaha test these sleds with this secondary clutch and if so wouldn't these problems have been seen on the test sleds. Maybe there is a issue with a supplier and the material they used. Wonder why some are having issues and some aren't?
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Most likely some kind of rolling change at the supplier level.
Either way, Yamaha has to own up to it. Seeing how it's a wear item, that shouldn't wear out, I wouldn't have my hand out, waiting for them to drop from the sky......
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
Mine has 480miles on it not babied one bit and no flat spots is it slow cruising that's causing this?
- Sauk Prairie, WI
- www.ty4stroke.com
I'm curious to know if all models are effected or just some of them? Early build sleds vs. later built as well. I've only got 50 miles on my RTX -SE and so far no wear that I can detect. picked up the sled November 25th
justin1620
- Feb 3, 2014
- Rainy Lake, Ontario
- Sidewinder
- www.rustymyers.com
In my 60 miles not many very slow cruising miles...I set the rings in pretty hard
rMine has 480miles on it not babied one bit and no flat spots is it slow cruising that's causing this?
super_rash
- Feb 24, 2014
What stresses me out is this is such an easy problem to solve, and i bet you it will take more then a year to solve.. first thing Yamaha said was "break the rollers in gently" i wonder, what has Yamaha officially responded to those who sent emails for this problem. I know if you send an email to yamaha canada or Yamaha US customer service, they will answer by email.. who has sent them an email so far and what has been their response?
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
150 miles on mine ridden hard, no flat spots - and the turbo bolts were nice and tight.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
The test riders experienced this and reported it to the top brass at Yamaha and it was ignoredWhat I don't understand is did Yamaha test these sleds with this secondary clutch and if so wouldn't these problems have been seen on the test sleds. Maybe there is a issue with a supplier and the material they used. Wonder why some are having issues and some aren't?
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
my sled was absolutely babied. 112 miles. i can't find an email, only phone in cali, which probably goes to india. i will let them know about loose turbo and flat spots, but don't want to shed bad light on dealer (good people) for the other things (fluids) that should probably be caught on set-up. can anyone answer this, the primary rollers also have the chrome or whatever coating worn down to what appears to be brass. is this normal? two of the secondary rollers have light flat spots. anyone have an email address? thanksWhat stresses me out is this is such an easy problem to solve, and i bet you it will take more then a year to solve.. first thing Yamaha said was "break the rollers in gently" i wonder, what has Yamaha officially responded to those who sent emails for this problem. I know if you send an email to yamaha canada or Yamaha US customer service, they will answer by email.. who has sent them an email so far and what has been their response?
super_rash
- Feb 24, 2014
if this is true, it would be a bad publicity and bad attitude IMO...The test riders experienced this and reported it to the top brass at Yamaha and it was ignored
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
relax guys I'm quite sure there will be a bulletin and if it wears the helix that will get replaced as well. If not then call customer service. Squeaky wheel always gets the grease.
- 7K
