jpr-ltx-dx 2015
- Sep 21, 2014
- sr viper ltx dx
Is there others whit that issue.mine have 200km and have a flat spot on a roller.yamaha say not cover.and back order for at least 3 weeks.i just saisd forget it and get 3 rollers from a 2015 cat driven and it fit there and work good so,have to let you know if you're in the same boat.the rollers have the same over all diameter,width,and center hole too.
roweboat70
- Jan 25, 2011
- 2017 Yamaha Sidewinder STX-DX
jpr-ltx-dx 2015, how did you notice the flat spot? What were the symptoms ?
BTW Heard a guy took his SW for the first service and the dealer noticed the flat spot on the roller, he said he didn't notice any symptoms.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 Apex GT 40th, 2008 nytro rtx, 2005 RS Vector MTN turbo, 2001 VMAX 600
The first time I saw the new roller secondary driven clutch it reminded me of the hymark roller secondary kits back in mid 90's made for yamaha's , what a piece of sh.... That was! But I assured myself these rollers are larger in diameter it'll work great. Hope I'm right
jpr-ltx-dx 2015
- Sep 21, 2014
- sr viper ltx dx
opened the side cover to take a look if all is ok and saw that flat spot on the roller.flat spot mean binding and binding is never a good thing in drive system.
- Apr 14, 2003
- Hessel, Michigan
1 of my rollers has a flat spot also. No issues...but as jpr mentioned..."binding is never a good thing"
Reinventing the wheel here and think a better, improved wheel with less slop is in order.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
the one with the flat spot is it touching helix or floating in mid air? I have one that is not touching helix and im guessing this might be the one that could or will develop a flat spot1 of my rollers has a flat spot also. No issues...but as jpr mentioned..."binding is never a good thing"
- Apr 14, 2003
- Hessel, Michigan
The one with the flat spot was not touching
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
I have had cams with bad cuts before? Aftermarket cam's?
- Apr 14, 2003
- Hessel, Michigan
All stock
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
DO the Cat rollers all touch helix. All three touching helix?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
http://www.ulmerracing.com/Secondar...&browse=-73647&shopBy=-26776&catalogId=-11683
We've been working on replacements for a while (since summer time).
I believe going out and running with 0 miles on it and going wide open instead of giving the rollers a little break in time, may cause some of the issue as well, but I can't confirm 100%.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I believe going out and running with 0 miles on it and going wide open instead of giving the rollers a little break in time, may cause some of the issue as well, but I can't confirm 100%.[/Q
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
good point Allen...maybe like brake pads they need to burnish in some...
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
found them on your siteHow about a better helix??
- 6K
