Flatland Supercharger
mnydir
Hope everyone hasn't discussed this a ton before, but what would be a good supercharger for MN WI MI. I would like to run lower boost and pump gas.
MPI is your only choice. I run one on my Apex in Iowa/MN/WI/MI and its flawless. If I had a nytro though I would look at a turbo just for the fuel range. Only turbo that coudl stand the abuse of midwest trail riding is Ulmers front mount and MCX's rear mount.
The only problem with mcx is you will get a ticket in wi for exhaust.I have a MPI stage 1.If I would boost again I probably would go ulmer turbo.Better fuel image and a cast iron manifold so you dont have to worry about it cracking from the turbo heat from trail riding being a front mount.
