1999 Fatboy
- Nov 15, 2019
- 2018 Yamaha SR Viper LTX-DX
I still run the stock twin keel skis with 4 1/2" and 6" Stud Boy runners inside and outside respectively, love the hour glass shape as they hook up like crazy on the groomed trails. I just checked them and the front of the carbides have worn considerably with little wear from the middle to the rear after 3000 miles, would this be considered normal or is a suspension adjustment in order? If so, what would anyone recommend? All settings are factory stock.
allyammies
Shim your skis it will do wonders.
Vmax
What can we use to shim rather than OEM
i usually use a chunk of rubber transport mud flap when i shim mine.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Agree you need to shim, I have used rubber, plastic, aluminum anything that doesn’t rot, rust etc under the rubber behind the ski bolt It will steer easier and better on groomed trails I usually look around and use what i have latest was a thick piece of plastic that worked great
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
I bought a nylon cutting board at the Dollar Store and cut it into shims.
1999 Fatboy
- Nov 15, 2019
I'll try shimming and post the results
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I ran a couple sets of the Stud Boy shaper bars on Curve skis and both sets wore out rather quickly just forward of center. This was on a Nytro with the ski rubbers shimmed. I liked the way the shaper bars handled but didn't like the uneven wear so I switched to Snow Studs round bar carbides which tend to wear more evenly.
Typically, you shim the ski rubbers to help reduce darting when using single keel skis. Dual keel skis usually don't have as much of an issue with darting. If you're going to shim the tuner skis in an attempt to correct the shaper bar's uneven wear I wouldn't over do it. Shimming the rear of the ski rubber transfers more weight to the rear of the ski causing heavier steering. Maybe start with 1/16 to 1/8" of shim to see what it does.
1999 Fatboy
- Nov 15, 2019
The uneven wear is my biggest issue, darting doesn't seem to be a problem, thanks for all the tips.I ran a couple sets of the Stud Boy shaper bars on Curve skis and both sets wore out rather quickly just forward of center. This was on a Nytro with the ski rubbers shimmed. I liked the way the shaper bars handled but didn't like the uneven wear so I switched to Snow Studs round bar carbides which tend to wear more evenly.
yamadoo
- Jun 3, 2003
The dollar store cutting board is just genius. Will keep in mind if I ever need to do again
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
I use old snowmobile belts.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The carbides if set up correctly WILL wear evenly front to back.. No way will shimming skis affect steering in a negative way if done correctly.. Have been shimming Cat skis for years.. The trick is to get the right thickness on the shim to create even wear front to back. Also the skis can be difficult to install once a shim is placed in the rear portion under the the rubber ski saddle. I used everything from old slides to heavy duty mud flaps. 1/4 thick is a good starting point.. Once you shim them and swear some getting them back on, you need to check wear often to see how its wearing and adjust if need be..
1999 Fatboy
- Nov 15, 2019
For a lack of finding anything else at the moment, I used a 2" long piece of a paint stirring stick as a shim (1/8" thick) yesterday and went on a 60 mile test run. Too soon to tell about wear, but, it sure seemed to turn much better especially on the hard packed and icy sections of the trail as more of the rear part of the skis, runners and carbides were making contact, I was making tighter turns than the sleds in front of me without pushing, I might add that no more effort was needed to actually turn except for the fact that I had to hold the handlebar tighter through the turn because I was actually turning. Today, I'll be in search of an aluminum bar I can cut to replace to paint stick and you're right, it was a bit tough getting the bolt started with the shim, don't know if I could go any thicker. Thanks everyone for your input and suggestions, this is a great forum for tips and tricks for our sleds.The carbides if set up correctly WILL wear evenly front to back.. No way will shimming skis affect steering in a negative way if done correctly.. Have been shimming Cat skis for years.. The trick is to get the right thickness on the shim to create even wear front to back. Also the skis can be difficult to install once a shim is placed in the rear portion under the the rubber ski saddle. I used everything from old slides to heavy duty mud flaps. 1/4 thick is a good starting point.. Once you shim them and swear some getting them back on, you need to check wear often to see how its wearing and adjust if need be..
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Your welcome. PM if you have any questions. I would look for rubber or plastics as a shim material.For a lack of finding anything else at the moment, I used a 2" long piece of a paint stirring stick as a shim (1/8" thick) yesterday and went on a 60 mile test run. Too soon to tell about wear, but, it sure seemed to turn much better especially on the hard packed and icy sections of the trail as more of the rear part of the skis, runners and carbides were making contact, I was making tighter turns than the sleds in front of me without pushing, I might add that no more effort was needed to actually turn except for the fact that I had to hold the handlebar tighter through the turn because I was actually turning. Today, I'll be in search of an aluminum bar I can cut to replace to paint stick and you're right, it was a bit tough getting the bolt started with the shim, don't know if I could go any thicker. Thanks everyone for your input and suggestions, this is a great forum for tips and tricks for our sleds.
1999 Fatboy
- Nov 15, 2019
I ended up using 1" wide by 1/8" thick aluminum bar stock I purchased at a local hardware store and just cut to length, drilled a hole and screwed it into the rubber, went in pretty easy.Your welcome. PM if you have any questions. I would look for rubber or plastics as a shim material.
- 148K
- 32K
