aquaticlaker
- Feb 21, 2009
- Green Lake WI
- SIDEWINDER L‑TX LE 50TH
- Green Lake Wi
Looking for some help! 2018 sidewinder with Turbo Dynamic flashes, 3 bar map sensor, blow off valve, CAI, sock muffler. I have a P1236 error. I have researched on this site and have done the following. Boost tested system and tights clamps, boost holds well. Attached is the boost and boost map data when at idle. Do those numbers seam correct? How do I get rid of the error? Sled runs fine just trying to get to the issue if any.
Mike
Mike
tsiceman
By your pics, it looks like you loaded performance muffler tunes. I think you need to load stock muffler jukebox. Hopefully someone will confirm!
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- Green Lake Wi
You are correct! My mistakeBy your pics, it looks like you loaded performance muffler tunes. I think you need to load stock muffler jukebox. Hopefully someone will confirm!
- 48K
