SIMMER
Hey guys,
I'm down to 2 tracks....same profile except one is fully clipped and one isnt. Whats the consenus on this? Is it better to go fully clipped or go with a track clipped every 3rd?
I'm looking at a Camoplast 9833 (clipped) and a 9818 (clipped every 3rd. I'm not running extroverts (been there done that) just running stock wheels.
I know there is weight, but whats the thought on running a clipped track without running extroverts?
4Fighter
I'd have to think long and hard before going back to a fully clipped track myself.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Fully clipped 100% all the way!!!
SIMMER
4Fighter said:I'd have to think long and hard before going back to a fully clipped track myself.
Let the debate begin...
Now you see why I'm having trouble with this? I get conflicting info from both sides. 4Fighter....why not clipped? Allan keep in mind that we ride alot of trails which are sometimes hard packed but most often not.
Yummy
If you don't run lakes or ice road and won't do WOT for very long; you can go with the clipped every 3rd else FULL CLIPPED.
Why you ask.
I smoke the ripsaw + all 6 idler wheels doing WOT for 10 miles on lake last year. Funny, the guys I was following had NO damage at ALL.
I put a 1"track full clips and using narrow sliders. I really think I made a difference, but having try a 10 miles long on lake yet.
bye for now
Why you ask.
bye for now
fxr
track
fully clipped and what did you do to your track?
SIMMER
fxr said:fully clipped and what did you do to your track?
100-120mph on the dream meter for ohhh....about 3 days...
The RIPsaw is now truly a RIPPEDsaw. It now has a 14"x3" section section down the center that looks like a skinned rabbit.
I called Camoplast and they said that anyone doing sustained high speeds should NOT be running a 1.25" track and the delamination is caused by heat build up from the lugs. Camoplast recommends a 1" track for riding like this but I just can't bring myself to go back to 1" track.
fxr
track
hey john i would go with the track rex is going to use. 9837h144. now that i am running a 1" track that mono suspension is a lot quieter. how is the excell exhaust noise on the long hauls?
pro116
I switched out the ripsaw last year for a fully clipped track.I will only buy fully clipped from now on.
SIMMER
Re: track
Hey that's real similar to the 9833 but in a 1" version. I'll take a closer look. Thanks.
As for the exhaust.....it's only loud when you want it to be....I love it! You can't even hear it over 50mph unless you crack it....which I tend to do often
fxr said:hey john i would go with the track rex is going to use. 9837h144. now that i am running a 1" track that mono suspension is a lot quieter. how is the excell exhaust noise on the long hauls?
RedRX1
I have 2 sleds running the ripsaw clipped every third window but opened every window. No problems so far and it seems to have reduced hyfax wear over the closed window track.
welterracer
yup that track is TOAST..
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
rxwonder said:fxr said:fully clipped and what did you do to your track?
Well if camoplast says the delamination is caused by heat build up from the lugs at sustained high speeds how is a fully clipped track going to help that???? Looks like the track delaminated inside of the clips.
LoneViper
I'll never go back to third window closed, just too much friction between the rubber and the Hyfax. Fully clipped just better all the way around.
Shiek
i changed out to a 1 inch full clip 6 pitch last spring much improved hyfax
wear,faster on top end.
- 42K
