Is it the same horsepower in all Stock fx nytros -08 --09 ?
A friend said that his stock MTX -09 has 144hp
and the older stock nytro-08 135hp
and i said its the same engine same power-whos answer is right?
//Mats
//Mats
theCATman
According to American Snowmobiler Magazine...... they dyno'd the FX Nytro at 138.6 HP
All the engines are the same.
2008 Nytro RTX
All the Nytro motor ar the same and coming in from 135-138.
Turk
Tech Advisor
An 09 100% stocker brand new just did 140 hp at dynoport.
Mtnviper
Vendor
Turk said:An 09 100% stocker brand new just did 140 hp at dynoport.
I saw that Wasn't sure if Allen had some milage/hours on it, or if the conditions were good that day for make'n horsepower! Either way I like it
2008 Nytro RTX
There the same motors,So I am sure there is 08s out there that are making similar HP
Daranello
Suspended
09 ARE faster than the 08, so I can beleive the 140hp's
Alatalo
Two different -08 FX Nytros were 123 hp and 124 hp at MCX.
Just as a comparison, in the same dyno, Phazers are ~77 hp and Apex are ~143 hp and my old ported and piped Viper was 163 hp.
Different dynos show different numbers and the number can always be controlled by the dyno operator...
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I dyno'd an 08 and tested several 08 ECU's (MTX, RTX, Std, etc) and also tested several 09 ECU's (XTX, MTX, etc) with no differences between the two. I would say all 08's and 09's will run between 138-140 hp on average.
Superman
Didn't somebody Dyno a 08 at 141 last year? I thought I remembered seeing one.
- Apr 17, 2003
- Menno, SD
- Menno, SD
There were several at 140-142. Excell motorsports dyno'd their brand new one last season at 141 hp at Dynotech. I was just there with an 08 and dyno'd 141 hp and my sled had 1000 miles on it.
loudelectronics
My birth sheet says 125!
Daranello
Suspended
if there new getting 140is, wont they produce allot more after the dreaded break in?
theCATman
Dear God, this thread is going to get as F'ing stupid & retarded as the subframe & handling debate.
Nothing but crap like, My brothers-aunts-cousins-ex sister-inlaw's-1st cousin's dad-once removed-uncle's brother-uncle '08 Nytro dyno'd at 3,000 HP and is faster than yours. His is a top secret special order that nobody else can get. All other FX Nytros at the Dyno that day were like only 95 HP and are getting totally bitch-slapped by 340 fanners
