bleedyamaha
- Sep 28, 2013
- Northern Iowa
8jp you should use the stock washers that are on the back if ya use a 8dn then you will need to add a extra washer to each of the bolts on the back of secondary40C4313 its the direct replacement for 8jp as far as washers I don't know you will have to check that out yourself I use a team secondary.
