Gearing question
ski
Manitoba Canada
Canada
2015 Yamaha Viper R-TX LE
LOCATION
Canada
Can I get away with running 21/48 gears with a 90 link chain, or will it be too long?
After review, it does look wrong... too much adjuster angle. I put the stock gears back in. 21/49
If your after more top end xtx gearing helps in the rtx and ltx cheap upgrade through Yamaha. Tons of info on it on here of guys doing so.
What gearing is that? Can I use my stock ltx chain? I think stock is 24-50
No xtx gearing is 21-41 86 link chain all through Yamaha very cheap. Canada pricing was under 150 I believe
Some rtx le with the 1.7 sno x track had 21 49 gears, not good for top end, but 0-70 was in a couple heart beats
I managed to pull 98 MPH with the 21/49 gears and it gets there very quickly. I'm kinda ok with that... because I'm out of money.
That's awesome, you must be doing something right cause most guys with them gears cant break 88 mph
I went to the yamaha dealer for 21/41 gears and chain and he quoted me close to 400$canadian. Please share where to get gearing for 150$
Right! Tell us more. Drivers 9t?
My sled had the rev limiter adjusted from Yamaha's race team. It was a X-country race sled initially. When it was being raced, it had no reverse and 22/48 gears. I was told it did 105 MPH pretty reliably... I have made some minor changes to the clutch set-up to make it a little more trail friendly and put the reverse back in which necessitated using the stock gears again (can't afford new ones right now)
This is a shot of it below winning the 2015 WOODY'S I-500 CLASS - FACTORY STOCK 600, riden by Cale Anseeuw #931. https://usxcracing.com/index.php/results/standings/2015-year-end-class-champs
Another action shot of him below... If I ever look half as cool as him riding it... I'll be pretty happy!
