powershot1
Has anybody hooked the gems controller to vacuum /boost
Instead of boost only
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
I don't run a Gems anymore, but if memory serves me correctly, you should be taping into the vacuum ports on your throttle bodies, and NOT your boost plenum anyway, which would be both boost/vacuum.
If I'm wrong on this one, someone chime in and correct me because it's been a while since I've played with a Gems controller, but I don't think the Gems controller will remove fuel from the oem tables? I'm pretty sure it gets its rpm signal from the injector signals anyway, and with that being said, I don't think you can use the vacuum signal to make it leaner than stock. Is that what you're asking about?
Gems controller has to pull from the Inter-cooler boost not the throttle body's.
FLYBYU
MrSled said:Gems controller has to pull from the Inter-cooler boost not the throttle body's.
- 13K
