Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
Thanks !!Ben, you can use the pictures if you like. I would be honored.
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
ben is your knock ,semi race and race map ready to be update on flashers yet ?Thanks !!
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
Semi-race has been in testing since last year. But I still consider it a beta map. Same with Full race map. I'm running it on a few sleds, mine and a few customers.ben is your knock ,semi race and race map ready to be update on flashers yet ?
You need a lot of parts to use the semi-race and full race setup (fuel pump, regulator, 3 bar map sensor, TD flasher, TD datalogger and Wideband o2 module)
All beta maps require the full monty setup because they are not finalized. And honestly anything over 19 psi it's good to start monitoring stuff to be sure the install is perfect and everything is working well.
The knock light we have not worked on recently we have been too busy. But I have plans to test shortly up north and complete the testing. temperatures are getting better each week.
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
thks!!! keep up the good work !!!!
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Don't forget the cool stickers that Ben sends with each shipment. I received my Exhaust, Intake, Flasher, & Clutching in separate shipments so I have enough stickers for my sled, trailer, truck, & garage beer fridge!
I have not installed any of it yet but will be soon. I wonder how many beers it will take to get all of this installed?
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
The common time is one beer per sticker so that would be 4 beers.. Just clean each surface with alcohol first. (rubbing alcohol)
As far as the speed parts.............i have no freakin' clue
DISCLAIMER: TY does not condone the consumption of alcohol while installing parts that make your sled an insane rabid animal
I have to drink after... drinking during bad things happen.. bolts fall out. wheels fall off.. I am to much a perfectionist.
type809
I dont attend or race at those events in the winter, I just dont have the time. I would rather be out trailer riding. I would have Shagman or NOSPro run at it. Hank has basically the same set up.
lhdriller
- Feb 17, 2016
- NW Ontario
- 03 Viper
2017 LTX-LE
Any updates on the Powertrail tune? What's your thoughts?
So far I have 300 miles on the kit. Works great and pulls hard. Need more time on it.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
Exhaust sounds awesome. Mellow with a little Eurocar rasp when your wot. Very trail friendly.Sitting on the fence about getting this tune, how is the noise level of the exhaust? I am likely going to go with the stock modified muffler,noisy exhaust likely to get you a ticket on Ontario
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
My TD Turbo Force muffler sounds awesome! Deep growl at lower RPM and a race car howl at high RPM.
Not obnoxious, I do not think it is even loud enough to get me a ticket in MN.
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Tom,So far I have 300 miles on the kit. Works great and pulls hard. Need more time on it.
What changes did you have to make to your suspension after adding the extra horsepower cause of transfer? Basically to keep the winder tame in the twist and turns of normal aggressive trail riding?
Tom,
Not sure what you are looking for. Would be set the same if it was stock power. I just had to use my brake more...LOL
- 10K
- 9K
