MyOutdoors
Assembling stub shaft tomorrow...shaft is in the freezer. My question is how much green loctite do I apply to the surface of the outer bearing to housing?
sideshowBob
Just smear the outer surface of the bearing so it is covered with a light coating of green...it will force any excess out when its assembled anyway.
stgdz
- Mar 27, 2021
- Buffalo MN
Man I hate green loctite removal.
That #*$&@ is like welding, it ain't coming off with our some extreme heat. Oh and once you get it apart and it's warm you have to wipe it off or it will reharden.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Thin coat - no gobs or drips.
That stuff means business- it sets quick and is a bugger when it comes time to disassemble
MS
MS
stgdz
- Mar 27, 2021
- Buffalo MN
If I ever use it, then its a single drop on the bearing and drop the bearing into a heated pocket.Thin coat - no gobs or drips.
MS
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Thats why its so expensive, you use one drop at a time and Good Luck … Thats some good chit man ….
