Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Lastly my offset shrank a bit. Does that make sense?
B4 snub shaft 61.10
After snubshaft 60.62
B4 snub shaft 61.10
Fords4life
- Dec 7, 2021
- South Dakota
Yes it makes sense, you moved the stub shaft outwards when green goober'n the reset, outwards closed the offset distance.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Does anyone know what the gap should be on a brand new sledTo start with I have .45mm between brg & housing. Idk if that's about what it should be. But I've never blown a belt.
Doc Harley
- Oct 17, 2016
- Here & there
I'm sure my brg was pretty close. But that's not the only issue.Does anyone know what the gap should be on a brand new sled
1) bearing being forced inward on housing.
2) shaft moving inward on brg.
I'm pretty sure when a belt explodes the primary slams closed pushing the shaft and/or bearing inward.
What makes the most sense is to button up both. Not to mention when I disassembled the assembly, the bearing came off the shaft with a lot less force then the bearing coming out of the housing. I was very surprised, as everyone talks about the housing/bearing.
Turboflash
- Mar 18, 2019
- Southern MN
Does anyone know what the gap should be on a brand new sled?
Turboflash
- Mar 18, 2019
- Southern MN
Read post 37.
Gap has no spec I can find. Bearing is installed flush to back of housing. Gap not that important. Offset important and making sure primary doesn't rub on anything on back side.
Doc Harley
- Oct 17, 2016
- Here & there
I would say there must be some point of reference. Once you set the brg in the housing you could take a measurement again, as a point of reference. Then when you pull primary off, after you blew a belt or whatever. You could remeasure and conclude if the brg had moved or not.Read post 37.
But like you say....just get your offset correct and verify that.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Simply mark a spot on your motor and measure to your inside sheave. Record and you can check it anytime
Doc Harley
- Oct 17, 2016
- Here & there
So, I got my secondary back from the butcher, I mean the machinist.
Asked to remove 2.25mm, he decided it would be better to remove 2.48mm...lol anyway.
I have .011 clearance between nubs and my shim. Obviously I have more room around the rest of the secondary. With thermal expansion should I grind those nubs down a touch?
Secondly, the snub is not true. It's not horrible, but I can definitely see it. (OCD, for sure.
Advise & thoughts are needed.
As long as some of the shaft is protruding at full shift you should be ok as you have a surface to shim to so you can establish desired offset.
If you can see your stub shaft runout visually you have a problem. Best to check the stub shaft runout with a dial indicator and ensure it is running true otherwise you will have clutch wobble which is not good!
Doc Harley
- Oct 17, 2016
- Here & there
Bob, it's stupid question time...do I rotate the clutch with the track or start it and throttle???As long as some of the shaft is protruding at full shift you should be ok as you have a surface to shim to so you can establish desired offset.
Is there a preferred spot on the secondary that would give me the most accurate measurement for dial indicator?
You may want to put that secondary on without spring, and fully open. Then spin it to make sure nothing on the backside touches anything.
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, have a couple issues that need to be reviewed.You may want to put that secondary on without spring, and fully open. Then spin it to make sure nothing on the backside touches anything.
1) make sure secondary runs true?
2) if it needs further work, how much can be cut from the high side to straighten it out
3) clearance behind secondary (which I have .011 to nubs/flashing) probably .040++, if ground down nubs.
I'm just saying it may come into contact with the bearing holder brace at full shift with that amount off.
Doc Harley
- Oct 17, 2016
- Here & there
I'll scope it out. Fixed sheave is $180, that's if I can find one. Ugh.I'm just saying it may come into contact with the bearing holder brace at full shift with that amount off.
First things first. I need to know if it's true or not....
