Team Apex
Just bought a 2007 Phazer for my son and it seems to take alot of cranking before it starts when cold. Once its been warmed up it starts fine. It starts every time in the garage but this hard start worries me when its going to be -20 outside. I just don't think the battery will handle it. Is this common with the Phazer or something I should be looking at?
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
They seem to whirl over for a bit before catching, mine does the same.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Have you charged/tested the battery? The only time mine is hard to start is the first start of the year after it was fogged and sat all summer. It took 3 atttempts to get it going this year. I changed the plugs last week and it starts easy now.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Are you saying right now/first start of the year or during the season when its cold?
Cubby
- Dec 14, 2009
Just first of the season. Even at -30 C after 1.5 hrs trailering I never had problems starting it. I'm on the original battery with 4,300 kms. I do have the cold start update on the sled.
- Nov 1, 2009
- 2009 Phazer RTX
Cubby said:Just first of the season. Even at -30 C after 1.5 hrs trailering I never had problems starting it. I'm on the original battery with 4,300 kms.
I was asking the OP when is he/she experiencing starting problems. But my phazer is the same no matter how cold it turns over great and fired right up. That is if the relays are not frozen.
smalltownpower
when our phazer is hot, starts on second crank, when cold say -25 outside it'll spin like 4 times before she goes. every phazer i've seen is a slow starter when cold.
phazerhawkdude
yeah i agree with all of the above. never had any issues even when its -20 F. the first start of the year is the hardest.
- Nov 1, 2009
- 2009 Phazer RTX
I seem to remember the 07's needing a cold start update. Bring your VIN to the dealer and see if they update was done/avalible.
If it is a new problem after storage I would test the battery under load.
If it check out, new gas/plugs.
After that you should be good to go unless there is a different problem.
Ricketts
- Feb 29, 2008
- 2007 PhazerFX
For the first start of the year I usually turn the key on and off 3 or 4 times, without cranking it, getting a bit more fuel in the system. I think with mine the fuel either evaporates from sitting or bleeds back into the tank. Priming the pump in this way a few times helps for me.
Rick
Rick
gibb73
- Mar 8, 2011
- 2007 phazer fx
my 07 fx was the same way....took about 10-15 seconds of cranking before it would start. Just installed the ecu from the cold start update kit...turns over 4 or 5 times and fires up right away (when cold).
p/n 90891-50146-00
p/n 90891-50146-00
brad d
- Oct 31, 2011
is anyone getting these update for free? or has that ship sailed?
i just picked up a 07 with 1078miles on it and it takes a long time for it to start firing.
and its not even cold yet, so im wondering how it will be when its frozen out there...
Cubby
- Dec 14, 2009
According to service bulletin S2007-11 the free offer expired Dec 31, 2009. But you may still be able to purchase the update.
Its too big to attach but if you PM me your email address I can send it to you.
nswsparky
- Oct 2, 2011
- North Shore, MN
- www.nsw4x4.com
- Phazer
Cubby said:According to service bulletin S2007-11 the free offer expired Dec 31, 2009. But you may still be able to purchase the update.
For $250 for the cold start thing it would be worth it just to let it crank for a while.
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
My 07 started like crap when I got it. after spark plugs and a Napa Glass matt battery she starts much better, stronger crank and less cranking time. Run premium gas if you can.
