Heated Seat Fail on LE Model
Bigblue1
NY
Sidewinder RTX-LE
Apex SE
Not that big of a deal but heated seat failed to work when I needed it most this year at -22 recently. Worked fine last year. Wiring looks good. No fuse for it so it must be direct connect to switch. Does the switch go bad? Again no big deal but I have so it might as well work properly.
wires in the seat are likely broken, had to change my heating pad already
Mine is not working too
Turns out i love toasted buns!
I'd be very disappointed.
Is it covered in warranty?
Did you wire it directly to the battery? I just picked the kit for my LTX SE.
I did with fuse and I added a LED light to bottom of seat thats on when heater is on. Its bright enough that at trail stops you can see in bag. Will get a pic for you. Really like the simplicity of this setup.
My buddy's blue 18 LE heated seat doesn't work either and hasn't since he took delivery. Gonna have a look at it this weekend and see if we can figure out why.
I put a btx seat on my 17 le if any ones looking for a le seat ?
Thanks for the tip. I like the idea of the light too. A pic would be great.
