rkkoeb
Hello
I need help, changing my track on my 09 apex and was using a video that I found but it was from a 2011 so the chain case setup is a little different. Does anyone have a break down of the chain case or a video I can watch?
Rick
Rick
Hello
Rick
2009 Yamaha APEX LTX_GT (RX10LTGTYL) Track Drive 2
Shop online for OEM Track Drive 2 parts that fit your 2009 Yamaha APEX LTX_GT (RX10LTGTYL), search all our OEM Parts or call at 269-385-1540
www.cyclepartsnation.com
rkkoeb
anyone have a video?
rkkoeb
ok what I am looking for is the install direction on the top shaft on the chain case. Once the inside cover is how I need to know the sequence of parts to go on. Sprocket, nut, spacers, o-ring, cover, etc?
rkkoeb
That is the first thing outside the chaincase. Settles into the chaincase seal
rkkoeb
So before the sprocket goes on?
rkkoeb
So would this by the sequence?
inner chain case cover
Spacer in pic
Sprocket
Thin washer
Large nut
Outer cover
O-ring
Spacer with setscrew
Brake disk
Washer
Snap ring
Spacer in pic
Sprocket
Thin washer
Large nut
Outer cover
O-ring
Brake disk
Washer
Snap ring
This locking collar is outside the chaincase. goes on just before the collar for the brake rotor.
Parts 23,22 and 25 are in the chain case. 23 is the seal where this collar sets into and the o-ring inside the collar seal the chaincase
rkkoeb
So am I correct with how I have it listed?
rkkoeb
That is the collar with the setscew. I am talking about the other collar with the oring inside of it
Did you have the complete chaincase off? If no set screw then could it be part #14?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
If no set screw it’s backside of chaincase on bottom.This is the part I need to know location for
