rkkoeb
Hello, I have a 09 Apex with a set of semi aggressive snowtracker skags on and running a studded 136 track. I feel that I get a ton of push through the corners and don't feel that it bits in well. What can I do to improve the handling in the corners?
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
I always found the aggressive trackers to work the best on the stock skis, semi’s didn’t have enough bite for me. Having said that, what is your transfer rod set at, and also your limiter strap? Are you pushing through the corner under power, or just coasting through?
rkkoeb
Pushes in all snow conditions?
What is your limiter strap and transfer setting?
kinger
Do you brake in the corner?
chris189
- Nov 27, 2011
- Hanover Ontario
- 2007 Apex GT, 1980 Enticer 340
I had Semi aggressive from previous owner on my 13. Pushed like crazy. I went to 6" shaper bars. Much better with very little darting. Best option for me would be c&a razors but way too expensive.
Like others said above, get more pressure on the skis. Choke up on limiter straps one hole and try that. If it's only when you are on the throttle then it's transferring too much. Set transfer rod to stock and try that.
Good luck
Good luck
