boone
Warrior 162 studs, track with 1" sag, all settings light, first ride [without studs] got 15 mpg gas. Now getting 12-13 mpg. 1300 mi on machine. Air box clear, only other mod is shut off valves. Also had to change belt squeling [spelling] when taking off up to about 10mph; new belt stoped that,but smell belt . help anyone boone
vmaxjohn
- Sep 19, 2003
- Midland, MI
- www.christyguest.com
I wonder if your shut off valves might be too small...this would starve the motor sometimes, and you'd wind up needing more throttle to do the same work...Otherwise, need to check out all the normal things. How's your plugs look?
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
What do you mean, AIR BOX CLEAR?
Did you gut it?
Did you gut it?
RX-1 Liter
- Apr 14, 2003
- Chautauqua County, NY
- 2017 RMK 155"
What kind of riding conditions are you in? If you are doing a lot of WOT ungroomed field riding 12-13 mpg is about average. The best I ever got on my shorty was 15 mpg.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
The worst I ever got on my shorty with Heavy Hitters was 15 :?RX-1 Liter said:The best I ever got on my shorty was 15 mpg.
boone
fuel mileage
VMax John never had the plugs out. TJ air box is stock checked to see if there was snow in it. RX1L no WOT but a lot of cross country riding. thanks for your reply
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Fuel mileage is a direct relation to RPM VS Speed, you can go through the tight and twisties and get poor mileage.
You can cruise at 40 at 6000 rpm or cruise at 60 at 7000 rpm and get better mileage at 60.
Clutch kit can kill mileage.
boone
TJ thanks for the info. I am going to my cabin next week there is a lot of miles of trails and I will see how it does just riding @ a constant speed. booneTed Jannetty said:Fuel mileage is a direct relation to RPM VS Speed, you can go through the tight and twisties and get poor mileage.
VT_BluYamaha54
- Dec 20, 2003
- Vermont
- 2012 Vector LTX
2004 RX-! Warrior
1984 Phazer (Antique)
Boone -
I think all of us may have missed/not understood what you meant in the last sentence: "smell belt".
If you smell belt, something is wrong. Either your brake is hung or something else is making it work too hard. Check clutches and be sure they are CLEAN and free of grease. Sometimes a mechanic will change the belt and have greasy hands - it doesn't take much - and this essentially ruins a brand new belt. There is allot of controversy about using cleaners on the aluminum surfaces of the clutches but isopropyl alcohol would be safe.
Let us know . . .
-VT_BluYamaha54
Let us know . . .
-VT_BluYamaha54
jim-bob
When I ride at a fairly constant crusing speed I'll get+ 15 mpg's/ however it's hard to keep your foot out of it when driving this sled/ the "FUN FACTOR" is just irrestable/ and even then I'll still get 14-14 1/2 mpg/ If your sled is proforming fine and there are no other problems I'd leave it alone/ later
boone
Vt54 from day one with the warrior I could smell the belt the primary clutch was very hot about 600mi put in larger shims in secondary ran it to 1100 mi then it would squeel up to 10mph. Checked off set it seemed ok with the floating secondary. Put in new belt you could smell the belt, turned secondary 3-3 to 2-6 only put a few miles on primary is a lot cooler but still seems a little warm.VT_BluYamaha54 said:Boone -
Let us know . . .
-VT_BluYamaha54
boone
jim-bob I am going to my cabin in the up of mich and there are a lot of long trails so I will be able to check it out. Its just you here of guys getting 16-18mpg with some wot so I though I would get a little better than I was getting. thanks boonejim-bob said:When I ride at a fairly constant crusing speed I'll get+ 15 mpg's/ however it's hard to keep your foot out of it when driving this sled/ the "FUN FACTOR" is just irrestable/ and even then I'll still get 14-14 1/2 mpg/ If your sled is proforming fine and there are no other problems I'd leave it alone/ later
Ski-Dog
The first 350 miles on my sled averaged 21 - 22 mpg (using canadian gallons) If its gets better when broken win WOW!!! Sled is tock at this time.
welterracer
Ski-Dog said:The first 350 miles on my sled averaged 21 - 22 mpg (using canadian gallons) If its gets better when broken win WOW!!! Sled is tock at this time.
Mine has guite a few mods done and i got 16.2mpg at 55mph avaerage and 13.1mpg at 70+ mph average... with alot of wide open throttle
- 49K
