Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Doc Harley
- Oct 17, 2016
- Here & there
Doc Harley
- Oct 17, 2016
- Here & there
And not to mention. What do I mark it with? I don't have the stud marker. Now what????
Paint marker at Walmart in the art and craft sectionAnd not to mention. What do I mark it with? I don't have the stud marker. Now what????
Keith Schmitz
X2
Keith Schmitz
Not sure on the ski doo kit, but on mine I covered all 3, and used epoxy to keep them set. As far as patterns, it's probably more of what you want, if you're using stud boy studs, I, personally would use their template (and I do & did).
Doc Harley
- Oct 17, 2016
- Here & there
Thanks so far. Looks like the patterns are too cLose to the middle. someone is saying, stay 3" from middle. But that's kinda impossible. Maybe I'm suppose to split it. Like 1 1/2" off center.
ApexXTX/Viper
- May 5, 2014
- 2019 SRX, 2018 Viper LTX
White chalk.And not to mention. What do I mark it with? I don't have the stud marker. Now what????
Keith Schmitz
I used little regard for the middle...I feel there is plenty of room as long as your studs aren't outrageously aggressive. I used 1.45...
Yamadog
I use liquid white out with the foam tip applicator. It cleans off the temlate easy when done.
Doc Harley
- Oct 17, 2016
- Here & there
Ok, thank-you so much guys! Just got back from Wally world. paint markers and clear silicone.
I have one protector, it's 33/34" long going to cut in into 1/3 which is approximately 11"ea. Going to try clear silicone to hold. Sound somewhat good?
One other thing.....should I heat the tip of cutting tool, with a propane torch?
I did it that way years ago? I thought it helps cauterize the track, so to speak?
Yamadog
I have never heated the tip it gets hot on its own if you spin it fast enough
Keith Schmitz
No, just cut. You'll be fine
Doc Harley
- Oct 17, 2016
- Here & there
Ok, last one. I just found that thread in regards to not studding up the middle, if using longer than 1.325???
I'm using 1.5? WTF?????
up.mi.man
- Feb 23, 2009
- Marquette MI
- 2017 sidewinder ltx se
- Marquette Mi right on trail 417
i sure hope i didnt miss anything but i just got the arctic tunnel protector?
- 39K
