Here is my NOS setup
Custom Rx1
What do you think more pick in the sled pic section. :nos :nos :nos
Tell us more about it!!
I need a tank in the back of mine like that.
Ok the tank is custom made it is 2 walled so the the exhaust will keep it warm. It runs the line under the sled up to the next bottle, where it has a Nos controller for the shot, it runs a blow of kit with two outlet out the front. So you can blow Blue Nos (coloured) with food colouring out. When you pull up beside some one and blow it off they look at you side ways.
It is like the movie fast and the furous cars.
Any more questions just ask?
Thank You :nos :nos
vid would be nice!!! LOL!!!
dude
that is kick A$$
I thought about blue LED's shining on my blow off.
how do you add blue to the NOS?
and let's see pics in action
how much NOS is that? my 2.5 runs out WAY too fast
Ramb
ok the one under the hood is 2.5 bottle, the one on the back is a full 10lb,but you have to put more pressure in the big tank to feed the 2.5 tank, so it dose not hold the full amount but all most. The blow off kit use's the pressure (air). from the tank that gets up to the small thank, and sits there. than run a line from the 2.5 bottle out the hood but at the T joint put in a injecter that will hold blue dust. Lets be onest who would want to throw a way good nos so use the air pressure. It is a very complex system but just keep asking if i did not ansewer your questions?
Thanks Ryan :nos :nos :nos
I actually pissed away a majority of my fist 2.5 tank showing the buddies the blowoff in my barn.
ran my first test run and ran out after 2 passes :o|
but I am confused when you say air vs. NOS
it's all NOS,
When the tank is about empty only gaseous Nos blows (clear) instead of liquid Nos vaporizing ( white spray)
I couldn't find your other pics as you mentioned
Ramb
yes that is what i ment, When the tank is about empty only gaseous Nos blows (clear) instead of liquid Nos vaporizing ( white spray) that is the stuff that i make blue. :nos :nos :nos :nos :Rockon:
