Pockets
07 fx, when i turn the key on the hibeam light is out. once started the hibeam light is on, when on low beam its dimmer but still lit, when switched to hibeam it gets brighter like normal and hte hibeam goes on. anyone ever have this issue or know what may be up with it?? doesnt matter how many times i hit the hibeam switch its awalys on when the sleds running.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Sounds like a short in the wiring. Do you have stock lights or LED's or Hid's? It's a PITA but check wiring from bulbs back.
Forgot to mention to check the actual switch itself and wiring down, some of these have had a problem with the main ground block. It can be found between the oil tank and Batt. It's wrapped into the harness and is a yellow block with approx 5-8 wires going into and out. It all depends if you have certain updates done such as hand warmer extra ground.
Good luck
Good luck
Pockets
Funny story friday was acting up rode sat was fine lol musta just been angry from lack of use (or at least thats what ill think till it burns to the ground lol)
canoehead
- Jan 14, 2011
- NE, Alberta
Sounds like a possible short or bare wire still.
Pockets
The lights functioned properly, no dimming or any other signs of a short. Ill have to dig around see what i see
canoehead
- Jan 14, 2011
- NE, Alberta
Electrical snags suck! IMO
Pockets
Indeed
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
check the modulation of the bi-axial plasma conduits... always giving me trouble
Pockets
but my headlight fluid is good
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
your not using the super blue fluid are you? the stuff that give you 20,000k super night vision?
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
I have seen the relay freeze and the lights don't come on. Maybe something simmilar happened.
Pockets
Nope got a smoking deal on the hyper white ultra light weight import fluid
Pockets
They always worked and wpuld switch high to low beam just the hi indicator light was dimly lit. I hadnt started in a few months so idk. Next day she was fine. Kinda weirdI have seen the relay freeze and the lights don't come on. Maybe something simmilar happened.
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
How many Kms?? Muffler bearing and the foo foo valve may need adjustment.
