Murse
- Sep 7, 2012
- Cornwall, Ontario, Canada
- 2011 Yamaha Apex Std Red
Speedos were off. My 11 is faster than my 06 was.
Murse
- Sep 7, 2012
My 06 ran out of gear at 186 km/h gps my 11 said 193 on speedo and it was not bouncing off the gear. I'm confident I may be able to hit 200km/h speedo which is 120+ mph
slowride06er
I have a 06 er that would read 126-128 on the dream o meter all the time before it got streached to a 136
new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
4years ago on lake ice road 06 apex 115 mph 01 srx 116 mph 03 rx1 113 mph all on gps
After 100 everything is just a blur anyways...lol!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
2015 xtx ape on groomed snow trail 111 gps speedo 115 best so far,it may be higher on better conditions,sled now has 2300 miles.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
ok,just bought an 07 apex rtx this year and the most I saw on the speedo was 105 on the speedo,should I be seeing more?
slowride06er
There's ="marty f, post: 1222312, member: 22386"]ok,just bought an 07 apex rtx this year and the most I saw on the speedo was 105 on the speedo,should I be seeing more?[/QUOTE]
Theres post about grinding off two teeth by your sensor to get a more accurate reading I wonder if this has been done
Shagnos
06 ER stock on hardpack. 122 speedo 107 gps 130 speedo 113 gps Oh and 144 picks down the center.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
2011 Apex XTX 110 gps on a hardpack trail. This with a fat guy on its back. Humungous windshield that I can't tuck behind and hide my frame. Skinny short guy would go much faster.
ydog
- Feb 4, 2015
- Berrien Springs, MI.
- 2014 Apex XTX
2012 Vector
2009 Nytro
I'm certain my new 2014 Apex XTX won't outrun my 2007 Apex top end but I wouldn't go back to the older Apex if you paid me to......lol......to many improvements to go back in technology.
zigoapex
- Feb 15, 2014
I have a o7' rtx,and the highest i got on the speedo was 117.The o7' rtx are the lowest geared stock apex trail sleds(mountian sleds are as low if not lower),and have the most torque.I had a 06' apex er,it had more top end, had it up to 125 on speedo. (was still climbing,but ran out of real estate)was better on gas (19 mpg,rtx is about 13 mpg)but wasn't as quick or had the torque of the rtx.I think i'm either going to put in the 23 tooth drive gear for next year,(ours is 22)and maybe play with the clutches.ok,just bought an 07 apex rtx this year and the most I saw on the speedo was 105 on the speedo,should I be seeing more?
up.mi.man
- Feb 23, 2009
- Marquette MI
- 2017 sidewinder ltx se
- Marquette Mi right on trail 417
111 gps on 2015 xtx i know theres alittle more in it though maybe 114.
zigoapex
- Feb 15, 2014
make sure the track has the right amount of tension on it,mine slows down if the track is to loose,it slaps off the tunnel.also,make sure the belt is a little higher than the secondary clutch,once my belt wears down to where it's even or a little below the secondary,it effects the top end speeds,and engages at higher rpms.ok,just bought an 07 apex rtx this year and the most I saw on the speedo was 105 on the speedo,should I be seeing more?
just fyi,new hyfax wears down real fast,but it stops right above the wear line,and doesn't wear anymore for a long time.don't change it until it gets below that mark.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I had that same 07 rtx w/ck skid and unstudded with 450 miles on ticker I ran it down the caribou rr bed at 112 gps cant remember just what the speedo was at,but many times I saw 127 on hard pack.I have a o7' rtx,and the highest i got on the speedo was 117.The o7' rtx are the lowest geared stock apex trail sleds(mountian sleds are as low if not lower),and have the most torque.I had a 06' apex er,it had more top end, had it up to 125 on speedo. (was still climbing,but ran out of real estate)was better on gas (19 mpg,rtx is about 13 mpg)but wasn't as quick or had the torque of the rtx.I think i'm either going to put in the 23 tooth drive gear for next year,(ours is 22)and maybe play with the clutches.
