bobber
machzrobbie said:bobber said:Been onto another thread here about an Apex running done a 600E-Tec where I mentioned about how my '03 600HO Rev outruns my '09 Apex LTX GT anytime under any conditions... more snow there is the farther behind the Apex falls. On GPS the 600 has ran 178km/hr.
Anyway today was out onto a lake with about 10-12cms of snow. Absolute top the Apex could show on its speedometer was 157km/hr. It does have stock track with 162 studs. Only performance add-on would be an Ulmer's Stage 2 clutch kit.
How long were you running???
About 2 kms. Machine just came out of shop where it had some parts replaced on skid, front swing arm (W-arm) had some factory defects, so track may be adjusted tight. However machine never had the top end most on this site appear to have. Also should mention rpm's steady at 10,800.
LightningPro
- Nov 13, 2004
- Traverse City Mi.
- lightningprollc.com
- 2011 Apex, 2006 Apex, 2004 RX Turbo
- Traverse City Mi
Curious question on this subject
If I have 2 teeth cut off of the speedometer sensor pickup gear and I am seeing 110 on my speedometer readout, what would the actual mph be? I get this in about 900 to 1000 feet.
Has anyone done a comparison of their gps to the speedometer readout that also has 2 teeth cutoff the speedo gear?
bluthru
LTX speed
'08 LTX with 5000k miles, running the track really loose, no studs, bone stock, snow-trackers, 110 mph on GPS on a fairly loose railbed. Thinking I should add studs, don't want to change the handling though? I pulled away from a studded '09 CF 800R in pretty good shape after a rolling start. The 13mm sway-bar and snow-trackers made a huge difference in handling, Any recommendations for speed/performance?
ZR800EFI
Re: Curious question on this subject
You are probably pretty close to dead on.
LightningPro said:If I have 2 teeth cut off of the speedometer sensor pickup gear and I am seeing 110 on my speedometer readout, what would the actual mph be? I get this in about 900 to 1000 feet.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
bluthru - welcome to the site
Would you mind adding your location to your user profile, it's a site requirement.
rxrider
TY Management
rxrider
TY Management
Skydog
Yea for a stock sled APEX have some big time top end for sure!!!! I say teens on GPS for sure.
Skydog
Skydog
Same day multiple stock apex out of the crate just trail studs in a half mile all ran between 114-116mph.Attack's where 112-114mph and clutched an mild mods on the apex's where all betwen 120-126mph.
This was all on glare hard ice on radar.
Skydog
WOW SICK!!!!
irondog rtx
I have had two rx1 03 05 two apex,s 06 rtx 07attak all seen just a hair over 120mph on dream meter 03 fast 123 apex rtx 121 longtrack 120 but it was hard pak and long ice run Im sure gps would show 7 to 10 miles off
zigoapex1
I had an 06' apex er that i got 126 on the speedo running across cranberry lake.
I have an 07' rtx now it's quicker out of the gates tops 111 speedo . It doesn't have the top end of the er.
rtx has the 22t and er 24t
I just put on a power module .it seems to have smoother power and a little more spunk.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Just how they are or at least were.
Speedo error around 10%.
Odos are right on the money though.
blackattak
My speedo IS off by 10% vs GPS. If it says 168 kmh on speedo then the GPS will be 151 kmh. Just started running with the GPS & the best I've seen is 164 kmh ( 102.5 mph). This is trail running, on a faster stretch. Last weekend with warm temps & soft trail, the best was 158 km. I simply set the Trip Odom on the GPS & check it at the end of the day, to see what the top speed was. Likely it will do a little faster, but on trails in my area by the time you get running top end you soon are coming on to a corner, so best to slow down!
Track has been loose, & was just tightened up, so it will likely pick up a little top end (if the trails ever harden up, I'll let you know). Sig has my mods, 10,500 km on sled, runs about 10500 rpm..
1yamman1
Mine is a stock 06 ER other then 0w20 oil and 10EK plugs and my max on GPS is 164KM on hard pack, and 172KM on ice radar run. Speedo is not even worth looking at, see 180+.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
1yamman1 - Welcome to the site
Would you please add your location in your user profile, it's a site requirement.
rxrider
TY Management
rxrider
TY Management
- 8K
