kinger
Per title where are you mounting everything if your using the stock air box?
stoutner
I'm Spraying one nozzle in each side of the air box. Some guys are spraying 2 nozzles mounted in the bottom of the air box. Either way seems to work fine.
My buddy just installed a Zex system in his car. It sprays the fuel and N2O in the air intake tube that goes into his intake throttle bodies. It is the same idea as spraying into your air box. It works pretty sweet on his car.
kinger
Where did you put your bottle then? The front nose area?
- Apr 14, 2003
- Hessel, Michigan
3 sleds
SRX - Using NOS components, (fogger nozzles), mounted into carb throat. Could use stock air box, but are open for racing.
RX1 - Using stock airbox, 2 nozzles mounted in the bottom of the airbox.
Attak - Using stock airbox, 2 nozzles mounted in the bottom of the airbox.
kinger
How do you like the bottle on top of the engine, thats a 2.5# right? Did you make a special bracket to bolt it to the steering column? Thanks!
big-d
my kids has an rs rage that he sprays 60 hp shot through. nos pro installed it 2 years ago. i have 60 hp but i have filters on my rx1
big-d
love the bottle on top.easy to exchange the bottle. 2.5 # bottle fits perfect. rs rage and rx1, fits perfect
- Apr 14, 2003
- Hessel, Michigan
Brackets came from Holtzman, and had to drill 2 holes. The 2 bolts on the bottom of the steering column get used.
I like it mounted on top for easy access, and ease of turning on and off.
kinger
Siphon or no siphon?
- Apr 14, 2003
- Hessel, Michigan
Siphon down and to the rear of the sled. If you look at it from the clutch side, it is at a 5 o'clock angle.
stoutner
Kinger,
Make sure you have a siphon. No siphon...no workie
I bought 2 bottles on ebay. They were supposed to have siphons but didn't...gave me fits. I went to home depot, bought about $5 worth of fittings and hose and made flexible siphon tubes. I put a heavy brass compression fittin on the bottom of the tube so gravity always puts the end of the tube at the bottom of the bottle.
motohd66
with my boss system i am using 4 nozzles spraying directly down the throats of the throttle bodies. just wondering, does anyone else have 2 bottles mouted like i do, one in the nose and one in the trunk? i told a guy that and he looked at me like i was on crack! guess i just gotta have a back up bottle.
- Apr 14, 2003
- Hessel, Michigan
I found out that a 2 lbs. bottle fits in the trunk of my Apex/Attak, but don't have a line to it. Just change bottles when needed.
kinger
Awesome, thanks I will look into a 2lb'er since I have a apex seat!
