Maine-Rider
Thanks everyone!
mrosenow
Stock pan looks thick? You've never had it off, have you?!? Stock pan might as well be a sheet of paper. It is worthless for protection. I bolted a skid plate on my RX-1 after I saw my buddy bend his heat exchanger right into his track on a chunk of ice. The skid plate was the first thing I bought for my nytro before it even had 1 mile on it. Best $75 I have spent on it. Saves me from totaling my sled.....yes, the insurance company will total your sled if you bust your heat exchanger. $75 saves you $7500. Is it even a question? They should come stock, yes!
Hornet Handler
Ironmanstl
Put the Ultra plate on and drill a few 1/4" holes in the lower ribs to aid with draining
Hornet Handler said:Check this out!
More info on this please...looks solid
Hornet Handler
shaddow44 said:Hornet Handler said:Check this out!
It is the new skidplate from Roest Racing. I got one of the first ones. They should be ready in 5 days. 3/16 aluminum, CNC machined to fit like OEM. All fasteners (stainless) are recessed or hidden. No crappy aluminum rivnuts. Doesn't deform or put holes in your side panels. Here are some final production pics.
Hornet Handler
mrosenow
Hornet Handler said:Here's a good example of why you need a real skidplate on a Nytro. Ripped the OEM plastic right off.
Your REALLY lucky. If that would have been a foot back, you could say goodbye to your heat exchanger. $75 part to save a total loss of your sled. Makes sense to me.
Ferraresso
Looks just like mine after last weekend's VT ride (fox floats down a little too far....) . I looked under the sled & noticed the stock plate was gone! The heat exchanger is really vulnerable without the plate for sure!
I am installing the Roest skid plate & Yamaha float plate this weekend. I am now a believer!
