Troops
Here is how I measure helix angles.
After doing a few you will get very good & very accurate at measuring any helix angle with in 1 degree.
You need a $10 angle finder with a magnetic base; a nut & a flat table.
stick the nut on the magnetic base
Keep the nut very flush to the helix ramp & read top angle on dial indicater.
Practice on a known helix so you will know exactly how the nut sits on the ramp.
Take readings top & bottom to give you dual angles.
You can also check the ramps midrange to see if it,s aggressive(keeps a steep angle longer) or a non aggressive cut(shallows out quicker).
After doing a few you will get very good at reading any helix & will allways be with in 1-2 degrees of the actual angle.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
THANKS TURK GREAT INFO
Turk said:Troops
Yep great info!!!!
So Turk where would I get this $10 angle finder?
srxguy
I bought one at Home depothlmrx1 said:Turk said:Troops
Yep great info!!!!
