jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I personally like the ulmers or thunder products rollers best. The cat are fine and will work. Just like the beveled edges on the Ulmer or thunder rollers better. The Cat rollers have a straight 90 degree edge on them. IMO the two I mentioned might roll the helix a smidge better. Not saying don't get the Cat ones. I used the stock for 250 miles then Cat for about 300. Then got Ulmers for the rest of miles. 1300.
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
Did the cats go flat?I personally like the ulmers or thunder products rollers best. The cat are fine and will work. Just like the beveled edges on the Ulmer or thunder rollers better. The Cat rollers have a straight 90 degree edge on them. IMO the two I mentioned might roll the helix a smidge better. Not saying don't get the Cat ones. I used the stock for 250 miles then Cat for about 300. Then got Ulmers for the rest of miles. 1300.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Not at all. They worked great. I just thought the others cycled a SMIDGE better on the helix. Honestly I just am to damn fussy. They were fineDid the cats go flat?
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
my cats also flattened slightly and had almost a melted appearance under magnification in a very short time, 45 miles? already had ulmers ordered too so put ulmers in and no problems under magnification in 200 miles yet. could hold my hands on the clutches with cats and all others in so not sure why.Did the cats go flat?
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
My stock belt, springs and rollers are all A1, 1200km
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Who said the stock ones were supposed to roll? they are merely round sliders, they have to 'flat spot" to wear together evenly.
After 2000km the oem on my sled were still very good whit no flat spot! I have replace them already for the D&D .... I think it s a poor casting on the secondary that make every sled different ! The roller and pin in the primary are BIG junk to!!!!!!
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
Didn't see anything on the website?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
AC part. My dealer had some in stock. Collin
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
2700 miles on cat torlon rollers they still look good. Will probably throw my Ulmer ones in just because for next season since it looks like we're done here.
Sent from my SM-G930W8 using Tapatalk
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
I installed the Turbo Dynamics clutch rollers as part of TD clutch kit last night. Getting the pin to drop out is the hardest part as noted before about the locktite debris. I like that these rollers fill the gap more making for less side to side action possible of the roller on the ramp. This is certainly not my expertise but I’ll bet that is the root cause of the flat spotting.
Also I started with a slightly worn ball end ratchet hex drive and that made getting one of th screws out a pain. I would not try this again without a good or new hex bit.
