KillerSidewinder
- Feb 10, 2019
- Ste Agathe
- Sidewinder XTX
Hold down top left while in psi thats how I did mine
Ok i guess that brings it to celcius and km the other way is Fahrenheit and mph or can we just change the temp. psi?IHold down top left while in psi thats how I did mine
It all switched overOk i guess that brings it to celcius and km the other way is Fahrenheit and mph or can we just change the temp. psi?I
Ok so here's what I have going on. My aled has always dropped 300-400 rpm by the time I would get to 100mph. I chased my tail thinking it was clutching. Today I watched the waste duty cycle and that goes to 35 to 38% and qradually drops back to upper 20s. About in line with the rpm drop. Boost drops about 1 to 1.5lb. Bad celenoid, bad pressure censor? I just did all the boot clamps so they should be good. Any ideas?That’s called wastegate duty cycle percentage.
This is a percentage of on/off time the computer cycles the wastegate valve. The valve is pulsed on and off at a fairly high base frequency usually around 10 times a second. The larger amount of time the valve is turned on it blocks the pressure from leaking out of the wastegate actuator. Higher percentages create a higher boost levels. Sleds with high boost tunes will have a larger percentage of wastegate duty cycle.
Should do a boost leak test for slight leaks. Pressurize system from turbo outlet.Ok so here's what I have going on. My aled has always dropped 300-400 rpm by the time I would get to 100mph. I chased my tail thinking it was clutching. Today I watched the waste duty cycle and that goes to 35 to 38% and qradually drops back to upper 20s. About in line with the rpm drop. Boost drops about 1 to 1.5lb. Bad celenoid, bad pressure censor? I just did all the boot clamps so they should be good. Any ideas?
I've been told that before so I suppose that should be the next step. I kind of thought the duty cycle percentage would increase if that was the case, computer trying to increase boost to maintain set boost?Should do a boost leak test for slight leaks. Pressurize system from turbo outlet.
