Hurricane 330 h.p. Mod Stock Pump gas.
Status
Not open for further replies.
Looking for something more
I’m really happy with sled set up is mint pulls like a freight train with no belt issues I feel it will still be reliable. I’m thinking the next level of performance is gonna need more stuff but for me am really happy.
Supper tips push hard on top. With shallower helix on start I needed 8 to 10 more grams depending on helix.
What track length do you have? I would imagine the gearing must bring your rpms down, because I run more weight than you for my 270 tune on a 129 and turn more than 8500 rpms, stock gears
137. With 24/38 gears. What helix are you running and set up?
41-37 helix, so Im sure that makes a difference too. Dalton black/green primary, white secondary @ 0-1, 2 tungsten heel, 1 tungsten mid, 4 washers tip.
Interesting for sure. I was running bare ice. On snow my rpms are higher. What belt are you running.
I can run between 79and 81g on the heavy hitters at 300 hp at 160 lbs in gear with the 45/33 helix. It's plenty of weight with the TP secondary rollers and the heaviest primary spring I can find .
Ya I was running bare ice today racing chiseled up, and with trail studs on ice earlier in the week. Was running 8jp this week. I seem to turn the same rpms with an 8jp, 8dn or xs825. The gates brings the rpms down a bit. 105mph is moving pretty good in 500 feet with trail studs for yours.
Status
