Pstn head
Makes sense, less restrictive and less turbulence air a few more hp. Hmmm
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Maybe I'm wrong. I'd have said the same if it was from any of the other shops. The 998 money train is coming to an end so I see this as another opportunity to suck some cash out of us. If it's that "restrictive" why has it taken 9 years of this platform to release this.Anybody who has delt with Dave would never say this. End of story!!
Just my 2 cents.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Huh?!?! Lol...this is Dave's supplemental way of giving you just that.
Earthling left a diagram. You basically cut appx five inches off the part 43. And replace it with Dave's new and improved turbo tube outlet.
To my knowledge when the factory inlet tube meets the turbo inlet you have like a 2 to 3mm step at the seal, inside the tube
I'm sure all of us agree that seal lip could easily cause turbulence. Thus the reason we port match/gasket match all of our intake & exhaust parts, It's really no big speed secret.
I say kudos to Dave for even wanting to bring this miniscule dollar amount part to market.
Think about it in terms of gross revenue in running a successful business. This part isn't going to keep him fed. Wouldn't even help to pay for the toilets when they're being flushed.
5/10 ponies plausible?!?! It sure can't hurt you.
I would rather have a tube like the aftermarket intercooler charge tubes right from cold air filter to turbo. One piece.
less pieces to loosen up and fall apart throughout the winter.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Same reason it took 8yrs to perfect the Knock out kit. Hahahaha....sorry had to.Maybe I'm wrong. I'd have said the same if it was from any of the other shops. The 998 money train is coming to an end so I see this as another opportunity to suck some cash out of us. If it's that "restrictive" why has it taken 9 years of this platform to release this.
Just my 2 cents.
Agree with all that you say DMC...it's all coming to an end.
But I look at things like this, if I'm the dummy that does the five things no one thinks are worth it, and I show up with a faster sled then X, well...that's the way it goes.
I refuse to run a header/tune which is what 10hp over stock manifold and costs $1,000 dollars. What do I need to do to make up for it???
Doc Harley
- Oct 17, 2016
- Here & there
Tim, I completely agree. But at what $300??? Ugh.I would rather have a tube like the aftermarket intercooler charge tubes right from cold air filter to turbo. One piece.
We'll see how much it costs when precision does it. Cuz they will do a full replacement tube.
Joe, the header tune is night and day over stock tune. Don't be mistaken on that one
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I doubt you’ll see anyone build a full tube . Most pro mods will remount the turbo to eliminate the stock tube to gain every possible bit of hp.
The stock turbo has been pushed over 400 hp on race fuel , I don’t think your going to see much more development
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I'm going to order one for a 2025 SRX build I have coming up. I will post when I try it on our chassis dyno to see if there's any difference.
Doc Harley
- Oct 17, 2016
- Here & there
1) extra heat & fitment issues bother meJoe, the header tune is night and day over stock tune. Don't be mistaken on that one
2) stainless steel mesh bellow doesn't work well with high temperature/turbo, or so I've read?!?!
3) the rigid bellows had durability issues.
4) just a bar hopper, I'll never run with the big dogs.
Ok, I'll wait to install till I get some outside positive reinforcement. Lol.I'm going to order one for a 2025 SRX build I have coming up. I will post when I try it on our chassis dyno to see if there's any difference.
It's not mesh. It's a flex pipe
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
But... it likely wouldn't be 3D printed. I am not really a PEFI tune fan... but they do make some nice parts.Now we will see pefi come out with there version at twice the cost lol
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
I think the 3D printed part is just a proto. Real parts are going into production this week I’m told. Thanks to Allen for getting us good dyno results!
Doc Harley
- Oct 17, 2016
- Here & there
3D.. Dave only made a handful of them, he must have sold out.
I'd "guess" 3hp@peak isn't out of the question, for me.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Damn Doc, you got one before I did! I'll be trying one on a 2019 SRX that's setup on C16 (PEFI header, larger intercooler, 3" PEFI straight pipe, wastegate locked, PEFI Intake with custom outside hook intake, Hypersports ECU, 1050 injectors, fuel pump & regulator upgrade, etc, etc, etc) at 32 lbs boost and then I'll try one on a 2025 SRX with PEFI Stage 3R setup (PEFI intake, fuel system upgrade, Sandale 2-1/2" muffler) as well.
Doc Harley
- Oct 17, 2016
- Here & there
Those are perfect test mules!!Damn Doc, you got one before I did! I'll be trying one on a 2019 SRX that's setup on C16 (PEFI header, larger intercooler, 3" PEFI straight pipe, wastegate locked, PEFI Intake with custom outside hook intake, Hypersports ECU, 1050 injectors, fuel pump & regulator upgrade, etc, etc, etc) at 32 lbs boost and then I'll try one on a 2025 SRX with PEFI Stage 3R setup (PEFI intake, fuel system upgrade, Sandale 2-1/2" muffler) as well.
You want me to send you mine, I'll get it out today. And you can ship me one later. No biggie....
- 6K
