yamagone
- Dec 17, 2008
- Essex, Ont. Canada.
- 18' Sidewinder
I'm running Hurricane's Hindle exhaust with their ST weight's. Running just the weights without any added weight I bump the rev limiter slightly at WOT. I added weight to the tip's to get rid of that problem. I'm no clutch tuner but what would you recommend if different than what I did? The only gauge I had to test my set up was running against a buddy with the same weights but not sure how he had his set up. We were dead nuts even past the C note from a rolling start.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Add tip weight to get the rpms that the tune recommends, I have 270 I hit 8950 and then it settles at 8850 hurricane recommends 8800 for mine.
yamagone
- Dec 17, 2008
- 18' Sidewinder
I'm not running a tune.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Personally i would load more the heel or center than tip.
You better inspect them periodicly those weight are dangerous for your clutches, pines wall are EXTREMELY thin and bushing collapses easily
I jave a brand new set( 300milles)for sale or trade if someone is interested...!
yamagone
- Dec 17, 2008
- 18' Sidewinder
Dangerous how? Both a bud and myself used them all last season without issues. I take my clutches apart after each ride. Nothing found out of the ordinary. Original belt 4000 km's.Personally i would load more the heel or center than tip.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
The weight profile is pretty good unless you have bigger primary roller.Dangerous how? Both a bud and myself used them all last season without issues. I take my clutches apart after each ride. Nothing found out of the ordinary. Original belt 4000 km's.
https://ty4stroke.com/threads/hurricane-supertuner-clutch-arms.145310/
yamagone
- Dec 17, 2008
- 18' Sidewinder
I don't.The weight profile is pretty good unless you have bigger primary roller.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I will not make friends, but it is dishonest to let his customers ride with this. These weight should be recall and replace by the manufacturer
yamagone
- Dec 17, 2008
- 18' Sidewinder
You still haven't stated what is "dangerous" about these weight's.I will not make friends, but it is dishonest to let his customers roll with this.
yamagone
- Dec 17, 2008
- 18' Sidewinder
Never mind I missed your response up top.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Add Bigger bolt in centre, Smaller bolt in heel as I recall were instructions from Dave.
Worked great for me. These Hindles make a fair bit more power.
Dave has recalled these weights for better bushings I believe. Byam was not the only one with issues.
The combo works well VS stock. 4 - 6 lengths in my favour vs a couple of stockers in 660 last year.
yamagone
- Dec 17, 2008
- 18' Sidewinder
I have the upgraded bushings from Dave, thanks I'll try the set up you suggested and see what happens.Add Bigger bolt in centre, Smaller bolt in heel as I recall were instructions from Dave.
