If you read back through this thread you'll see my track is fully clipped.
I still can't fully explain why my sled was having such bad hyfax wear when others weren't.
At the time, the conditions weren't great, but they weren't terrible. My track was "just" tight enough to not ratchet much (still once in a while). My snowflap was stock. I still suspect it was something to do with setting up the sled with a slightly higher ride height that lead to both the need for the very tight track and ultimately the worn hyfax.
What I did and I can now say without a doubt it 100% fixed the issue was install anti-ratchet drivers so I could loosen off the track and then bent the snowflap down a fair bit so it sits lower. Both of these definitely made very noticeable improvements.
We just got back last night from doing the loop from Kirkland Lake, Timmins, Chapleau, Hornpayne, Hearst, Cochrane, and back to Kirkland Lake and almost all of the riding was either on virtually solid ice (refrozen snow), rock hard snow, or in the worst case mostly bare ground with patches of rock hard snow/ice every 20-50 feet. To be honest, most of the conditions looked awesome and were great to ride on. There just wasn't enough loose snow/ice chips to lube and cool the hyfax. There was only about 50 miles or so that I would consider very poor conditions.
My rad fan probably ran 25% of the time and 100% of the time when the conditions got bad, but my hyfax survived with a about 3mm left (before wearing through) and my engine temperature light never came on while riding (once after a short shut down, but then it went out after about 3 seconds of idling).
The Apex ER (fully punched and clipped Ripsaw with 48 studs) I was with on the other hand didnt fair so well. 3 pairs of hyfax worn out (2 right through), a pair of skis (worn through) and an overheating light that came on several times on the trials. After the 2nd pair of hyfax went we loosened off the idler wheels and made sure they were tightened at the lowest position and this helped a lot after that (hyfax wore to probably 0.5 to 1mm before breaking through and stopped there).
We put on over 1500km and my sled and I are still ready to go sledding if there was snow (although it appears my sled now doesn't really need much snow...).
