Mountaintech
There is definitely something going on with your sled. Check out the link I posted.
http://www.snowestonline.com/forum/show ... p?t=201469
If sled is still under warranty your dealer should be dealing with this. Time to really rattle their chain. If they are not mechanically competent I would go elsewhere. Enticeraised brought up some good points. It could even be the waterpump. Everything needs to be checked to make sure nothing is plugged or inoperative.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
Roest said:There is definitely something going on with your sled. Check out the link I posted.
Thanks much...the sled is under warranty and has just over 300 miles on it. It's overheated from day one and I've tried to fix it with no success.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
enticeraised said:Order of troubleshooting: check for air pockets, check thermostat, pull rad to flush, lastly check water pump. Simple fix...I have over 7000km on two of these sleds in ALL conditions-never been an issue.
Thanks...I'll pass this on to the dealer. Another question? Do you guys hear your radiator fans come on or off? Do the fans run for a while after you shut the machine off like my Grizzly? I ask because I've never heard or sean the fan run...
ShootToThrill
billymx815 said:4strknytro said:What did it look like in there when you pulled the cap? When you pulled the cap it just sounds like the system holds pressure and was boiling the fluid. I had a gritty gunk in there when I opened mine up.
Honestly it looked somewhat clean with one exception...There was some white filmy particles.
Could also be a bad head gasket or cracked head from factory.
stock
You can hear the fan run, and it turns off with the motor. Can you see if the water is moving with rad. cap off and motor running ?
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
stock said:You can hear the fan run, and it turns off with the motor. Can you see if the water is moving with rad. cap off and motor running ?
No on both accounts...Can't hear fan run and don't see coolant moving...That's not a good sign.
Yammerhead
Are you sure the temp sensor is accurate? Maybe it's out of spec?
Remi
It's boiling...... That's accurateYammerhead said:Are you sure the temp sensor is accurate? Maybe it's out of spec?![]()
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Sounds like a factory defect to me... Send it back and start writing letters. My .02
Sno Cat
Best dealer in Maine bar none is Whittemore & Sons in Skowhegan, you'll have good luck there.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
Sno Cat said:Best dealer in Maine bar none is Whittemore & Sons in Skowhegan, you'll have good luck there.
I may be making the trip there if the dealer in southern Maine can't fix. I wish they would just through the tunnel exchanger in and be done with it.
enticeraised
billymx815 said:Sno Cat said:Best dealer in Maine bar none is Whittemore & Sons in Skowhegan, you'll have good luck there.
This won't solve your problem. Something has failed in your system. Start calling all dealers local to you before warranty is gone-demand results. If you haven'
t done damage to this motor already you will if you keep operating like this.Mountaintech
enticeraised said:billymx815 said:Sno Cat said:Best dealer in Maine bar none is Whittemore & Sons in Skowhegan, you'll have good luck there.
This won't solve your problem. Something has failed in your system. Start calling all dealers local to you before warranty is gone-demand results. If you haven't done damage to this motor already you will if you keep operating like this.
X2
cawcislo
Somethiing doesn't sound right. Could it be a water pump? I'm also wondering about a blown headgasket? Have you checked or someone checked the compression across the cylinders? It is also not good that the sled is overheating that bad that it's boiling over everywhere, you could possibly warp the head etc.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- Maine
cawcislo said:Somethiing doesn't sound right. Could it be a water pump? I'm also wondering about a blown headgasket? Have you checked or someone checked the compression across the cylinders? It is also not good that the sled is overheating that bad that it's boiling over everywhere, you could possibly warp the head etc.
She's at the dealer now and i'll keep everyone posted. I'm making sure they check everything under the sun before I take it back.
