Installing ski spindles
ViperTurboPete
Sudbury, Ontario
Canada
2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Okay...next question.
After installing oilites in the spindle what is the easiest way to put the ski shaft into the spindles?
I have the a-arms and spindles installed on the sled and am trying to stick the splined ski shaft up into the spindles with no luck. It is an extremely tight fit.
Do I take the spindle housing off and pound that onto the splined shaft?
Any suggestions? Funny how everything literally fell apart when I dismantled, now it is a different story.
your knuckles are probably bent thats why they dont want to go in look at them closely i had the same problem i had to use the plastic bushings they are not as tight of a fit
