Instrament cluster, Guages not working
PaulyTyrio
WI
Yamaha
My wife has a 2012 Yamaha Vector .
I just replaced the battery and it starts just fine. However, the guages do not work at all.
I checked all fuses. They are good. All lights are working as well.
Is there anything else I can check before replacing the instrument cluster?
Did you check the connection on the back of the gauge ?
Yes. It have slight corrosion on 2 out 10 pins. I cleaned it and applied dielectric grease. I checked all connections on that wire harness.
Do yourself a favor. Remove the connector again and flush out the die-electric grease. This grease insulates the electrical from make proper contact. Found out the hard way. I know use the Farmer's fix which is just ordinary gun grease in my electrical connections.
i use a product called pendilube on all my connectors every year. working great for me. was made for led light corrosion issues on transports.
