And its straight rate? Awesome. ThanksI got mine from Zbroz
stingray719
Me too! Now where did you get your straight rate spring? Was it Z-Bros?[/QUO
ZBROS Racing 20-0-800-160
or 20-0-800-145 for the 145 pound spring both are longer than stock. The 145 may suit you.
Robinmaine
- Apr 26, 2015
- Sabattus
- 18 SR Viper LTX
Yes straight rate $60.00
Thanks guys I will order one up. Will stick with 160 it rode fine in little stuff and worked Awesome in the big ones.
I have a spring tester I will bet that my stock center shock spring was bagged out at around 5000mi. Was adjusting it tighter and tighter end of last season. This will last longer and wont have to put so much preload on it.
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
With changing the spring do you have to have the shock revalved? Reason I asked I just had my shocks revalved this summer and I don't want the revalve fighting a different spring(sorry if this is stupid question I don't know much about shocks). If it doesn't effect anything I might have to pick one up and try it for my ltx!
Alsim
- Oct 6, 2014
- LTX SE 2018
I put 150mi on last thursday with the cat version. It is dual rate. Spend the $ and get a straight rate like Stingray has. I ended up putting so much preload to get rid of heavy front that the dual rate tightly wound part of spring was totally compressed and was no longer being used anymore. Straight rate is the way to go. That said I did find the sweet spot and was easily able to get front end light for even 4 ft rollers at 60mph "Testing". Higher rate helped alot. Not sure if you can see them in pic but this was ungroomed and big nice rollers for 30mi into Baraga. FUN!
I tried the 160 cat's spring and bizarrely I have to increase the pressure in the rear to limit the botomming ? Weird ...or maybe blew out my rear fox ?
Maybe but more likely you just didn't crank preload up enough to get into the main spring on that cat dual rate. Bet I went a good 1/2in or more.I tried the 160 cat's spring and bizarrely I have to increase the pressure in the rear to limit the botomming ? Weird ...or maybe blew out my rear fox ?
yamahoor
- Jan 4, 2015
- 2015 viper xtx
Do you know If yam. Or cat offers the 160 spring in straight rate or is strictly dual?And its straight rate? Awesome. Thanks
Dual is all I found in cat or yamaha
Alsim
- Oct 6, 2014
- LTX SE 2018
Hi cannDual is all I found in cat or yamaha
Hi Cannondale!Dual is all I found in cat or yamaha
Did y nitic
Did you noticed a big improuvement with 160 Zbroz's spring vs 160 cat's ?
Or simply crank it more will do the job. If not I will go with straight rate
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
Has Yamaha changed the spring on the '16 XTXs? I checked the parts catalogue and both the '15 and '16 XTX center spring's have the same parts number.
I ordered the 160# Zbroz spring but because shopping to Norway was way too expensive I shipped to BOP so he could ship it together with my Curves to Norway. Unfortunately there's been a shipping incident and the address label had fallen off, so the package was returned to US and is now MIA :O Hopefully USPS can locate the package and send it back to BOP so he can re-ship it to me.
But in case I don't get it before my first trip end of this month I wanted to order a spring from Yamaha, as I have a local Yamaha dealer. Does Yamaha have a 160# spring and what's the parts number?
Birkebeiner
Birkebeiner
I dont believe cat or Yamaha have a straight 160. I have the cat dual rate in right now and Zbros straight rate on order. Get a straight rate.
It wont affect rebound as bad as having your stock spring cranked up. So Go for it. Mine are all revalved.With changing the spring do you have to have the shock revalved? Reason I asked I just had my shocks revalved this summer and I don't want the revalve fighting a different spring(sorry if this is stupid question I don't know much about shocks). If it doesn't effect anything I might have to pick one up and try it for my ltx!
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Until I get my Zbroz 160# spring, I guess a dual rate 160# spring should be better than the (115#?) stock spring? If I can get it from my local dealer for a decent price, that is!
Birkebeiner
