Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F, '79 Trail Fire
In the 3500 miles my 2014 Viper has on it I've never had a problem with the reverse actuator. I've actually taken it out sucked out the oil putting oil back in and put it back together a couple of times and not had any issues. Today I went to change oil in the case once again and after taking the actuator off I found a small black plastic cap that look like it had broken off the bottom of the actuator. I also found a small rubber ring with a stainless steel pin in it that had a flat on one end. I've attached a picture (pic didn't come through with this post, look two posts below for pic) of what I'm talking about. Now when I put the sled back together it will initially go into reverse but will not go back into forward. If I remove the actuator from the case, start the sled and then hit the reverse button, the actuator does move into forward and reverse but when I put it back on the sled with the preload, it will go into reverse but won't go back into forward . What are your thoughts?
(See attached work instruction for the actuator I replaced the OEM actuator with)
YukonMP
- Dec 25, 2014
- Yukon Territory
My guess is that you have reverse issues ... I know ... what a genius yer thinking. There is a thread on this in the Viper FAQs and a search will yield at least a half dozen helpful threads.
Mills
- Dec 4, 2007
I guess my picture did not come through the first time. Here is the pic of what is broken
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Possibly Bushing shot on top gear in chain case. Time to open it up and disassemble to inspect.
Mills
- Dec 4, 2007
1nc2000 -- I can easily shift it into reverse and forward manually using the gear extension and a pliers so I am not sure that there is anything in the case that is bad. The broken part is on the actuator itself per the pic I attached. Can you explain what the issue with the bushing in the case is and how it would effect the actuators ability to not shift back into forward?
Thanks,
Thanks,
Mills
- Dec 4, 2007
One other thing I noticed. With the actuator off the case it does work in both forward and reverse directions with the reverse button while the sled is running like it should but, when I shut the sled off, it rotates in the opposite direction from the previous cycle by itself. Is this and issue with the actuator also?
Mills
- Dec 4, 2007
So after doing more research the actuator turning when I shut the sled off is supposed to happen so that is not the issue. I also found a thread about the internal plastic ring gear going bad and being able to re-clock it 120-180 degrees so I am going to look at that next. I still have a question about the case of the actuator being broken like shown in the picture and what the small SST pin is with the rubber ring around it. I am going to take the actuator to the local dealer this afternoon after work and have them look it over and test it.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Thanks,
I have the same issue of not shifting into fwd on my sidewinder. Reverse actuator was replaced with new and still won't shift into fwd with actuator. I can shift it manually with the actuator off the chain case. Gear was on back order so I finished out the season with no reverse.
Mills
- Dec 4, 2007
Did you find the root cause? You mentioned a gear on back order, which gear? Tell me this is not a problem internal to the chain case!!!!!!I have the same issue of not shifting into fwd on my sidewinder. Reverse actuator was replaced with new and still won't shift into fwd with actuator. I can shift it manually with the actuator off the chain case. Gear was on back order so I finished out the season with no reverse.
Your actuator is shot. The worm gear poked through the housing
Mills
- Dec 4, 2007
that is what I thought. What is the small SST pin with the rubber grommet around it then? that was sitting in the boss that runs along the bottom of the actuator housing on the case.
Also, someone mentioned on T.Y. 4-stroke that this actuator is the same as used on a Saturn car and that the car actuator is WAY cheaper than the one from Yamaha. Does anyone know what the Saturn part number is?
Most times this is caused by not clocking it close enough on install and forcing it too far to get screws to line up. That worm gear is spring loaded but can only move so far. Always manually shift into forward (counterclockwise) then install extension and detent without disturbing full forward engagement.
Not sure about the pin you found. Will look at one I have apart.
Yea both those pieces are from the actuator. The pin part with the pin in it is what the gear assembly pushes against. Like a bearing. If you have been installing it correctly the other cause of this could be if it lost home from the magnets on shift fork being so full of crud the sensor didn't stop the actuator in time. You really need to take cover off case and inspect and clean it properly. Sucking it out is not enough at least with any more than 1500 mi on it.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I guess my picture did not come through the first time. Here is the pic of what is brokenView attachment 148503
been there, done that
unfortunately That thing is junk.
