is this a problem?
dexter
Maine
while changing my oil I noticed the rubber hose that runs through that opening under the engine has been chaffing on the frame. it's this bigger of the two hoses you can see in the pic. Is this common? can I just put another piece of hosing around it to keep the chaff down? also, the hose and brass colored pipe it's connected to have a slight bit of play in an up and down motion.... thoughts anyone? just want to be proactive and not have issues this winter. thanks!
chit... LOL I was thinking atleast some radiator hose. thanks for the reply.
The wiggling is also normal. Wrap it with another hose or something and you will be fine. The hose is actually tough as it is and probably wont be a issue anyway.
thanks boys... appreciate the quick input.
