rxwhopper
i will have to try a 0-1 , i had it on 3-3 and it has been working. when you drive it doesnt seem like it makes much of a difference. but there is no way you can run it with a 1/3 wrap at 3-3
piskapo
- Feb 18, 2012
- Barrie
- 2014 Viper LTX-SE 240 Hurricane Turbo Kit
Let me know how it works out for you rxwhooper. I may do this with mine as well.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I did. You have to---thats the point of the vidieo. That purple spring is MEAN!!!! It takes 2 people to wrap that thing if you don't have the tool.i will have to try a 0-1 , i had it on 3-3 and it has been working. when you drive it doesnt seem like it makes much of a difference. but there is no way you can run it with a 1/3 wrap at 3-3
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
Did you notice any performance different from 3-3 to 0-1?
kodak
What are you running Joshua I am 3 and like Dave said and have not had much snow but So far seems good not a lot of good hole shots but so far no rev limiter.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
It would hit the limiter less. It seems to be holding the shift to long.Did you notice any performance different from 3-3 to 0-1?
Joshua
- Apr 14, 2010
- Newfoundland
I was running 3-3 but it was hitting the button pretty hard this past weekend. So I e-mailed Dave this morning and he suggested to run 0-1. I changed it this morning but have no snow to try it. I never hit the rev limiter with the 3-3 setup. I'm thinking the 0-1 is going to be better due to the tension now on the spring as compared to the 3-3 setupWhat are you running Joshua I am 3 and like Dave said and have not had much snow but So far seems good not a lot of good hole shots but so far no rev limiter.
HURRICANE
Allen ulmer tested the secondary spring at 0 and 1 early in the fall and felt that it would be a better setup then the 3 and 3 setting.i wouldnt comment until i could test it too.after several sleds tested, i agree with allen.the 0 and 1 setting removes a clunk and back shifts a bit better as it raises the rpm's about 100rpm
dave
dave
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Are you saying you are were setting it to 3-3 and pushing the helix straight down with no twist?
kodak
I just set my helix to 0 and 1 but had to remove my secondary clutch to do so when I installed it cant be sur it is in the place on the spline that it was is this important also my clutch has a 1/4 " freeplay in and out is this okay tried to put helix on while clutch was still on the machine man that was something. any help from someone who did this would be great. Thanks
kodak
anyone?
Joshua
- Apr 14, 2010
- Newfoundland
You mean once you were done you could move your secondary in and out on the shaft? If so that normal. It's not easy to whine that spring. I found it hard to put the belt back on, since the helix was wounded so tight
kodak
Man that spring was tight did you leave the secondary on the machine to do it or take it off and install helix
Joshua
- Apr 14, 2010
- Newfoundland
No I took the secondary off. I never tried it yet, but trip planned for this weekend. Will find out then.
- 48K
