I didnt remove my inner case either. Will be next time. Just check all bolts holding it in then.
Koyo 6206 is what both my Viper shafts have clutch side Jackshaft.
6206
Jackshaft is stepped.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I know
I have 2 new 6206 in front of me FAG(korea) and Nachi. To big id :-/. I was so sure i put the old one in the garbage at my friend shop
6206 id is 1.18in or 30mm almost flat whit zero tolerance in chain case. Clutch side jackshaft 1.106in - 28.10mm
Sorry. I have only changed whole assembly but bearing says 6206 right on it and parts fische says 6206. Who knows with Cat involved. All I can suggest is order a new one from dealer and let us know what you get.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
- That's what i did, they had one in stock which is miraculous. haha. 6206 "standard" 30mm id is the one in the chaincase the one behind the drive-in is 6206RD 28mm id only available at the dealer. That's the answer i got in 2 different bearings place. At least it's a KOYO(made in japan) 50$ ...lol
Good to know!
