DaveRX1
wryan_garner4
looks great.....wanna make one more?
ecopter
Where can I find screen like that?
Jon
Jon
DaveRX1
Any industrial steel and aluminum supplier will have expanded metal. The problem is: you would probably have to buy a 4x8 sheet. I would stop by a local fab shop (like I did) and beg for scraps. You do not need much I got a 12"x12" piece for free (way more than enough)
Good luck and happy hunting!
I also just added a radiator guard. I used metal gutter guard and cut it to 12". I doubled it up and then dipped the sharp edges in "grip dip" I then painted the guard black and attached with three zip ties. I glued four 3/8" x 2" metal tension pins as a spacer to keep the guard away from the radiator fins
Here are some photos.
http://s147.photobucket.com/albums/r306/WIYamahaPics/
SharkAttak
nice job, i still think it might need a pre-filter to keep the snow out, what do you think?
You are probably right. I will add a SLP snow filter after my first ride if needed.SharkAttak said:nice job, i still think it might need a pre-filter to keep the snow out, what do you think?
My hometown in N. IL got 14" last night/today! I moved to NE WI and we got less than 1".
northwoods
WIYAMAHA said:I also just added a radiator guard. I used metal gutter guard and cut it to 12". I doubled it up and then dipped the sharp edges in "grip dip" I then painted the guard black and attached with three zip ties. I glued four 3/8" x 2" metal tension pins as a spacer to keep the guard away from the radiator fins
Don't you think that it will make your engine overheat? Looks like it will restrect the air flow a lot. I covered the grill on a truck once to keep the bugs out of the radiator and it made the truck run a lot hotter
The guard is the same as what they sell on e-bay. My photo makes it look like it will restrict the air flow because it is black and the radiator is black.
See the site for the e-Bay guard.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... mot_widget.
My guard cost me leass than $5 from Menards and only took about 1 hour to build.
- 47K
- 8K
