Sidewinder 02
- Oct 27, 2018
- Framingham
- 2018 Sidewinder
looking for help on stud length and amount of studs to install on this sled ?
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
1.450 GD 3 per bar IMO,also depends on what riding style you do.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I run 1.575 megabites. Make sure to run your track tight and you won’t have any issues.
You can also use the search function as this topic has been discussed plenty of times.
Sidewinder 02
- Oct 27, 2018
- Framingham
- 2018 Sidewinder
I used to run a 1998 Thunder cat ,,with 210 HP and I ran 300 studs...hooked up great ..I kinda ride aggressive trail and don't want to spin out hooking up1.450 GD 3 per bar IMO,also depends on what riding style you do.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Wow and that did push you in the corners. Good luck I’m sure there will be a lot of people chiming in.
Sidewinder 02
- Oct 27, 2018
- Framingham
- 2018 Sidewinder
no it did not push in corners ...
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Awesomeno it did not push in corners ...
full tilt viper
- Dec 25, 2009
- Nytro MPI Stage 1
1625's
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I run 192 1.45" sharpened Megabites. Hooks like a cat on a screen door. Actually it hooks a little too good for a trail sled. I'd do 3 per bar next time.
DMCTurbo
- Nov 12, 2005
I'm sharpening my Megabites as per your instructions as we speak. I'm dropping from 192 to 144. I'm anxious to try them on ice.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
192 1.630 lake racers with stm tunnel protection... judging from your past... you expect to hook up... go big or go home
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Are you guys sharpening with the biteharder tool?I'm sharpening my Megabites as per your instructions as we speak. I'm dropping from 192 to 144. I'm anxious to try them on ice.
DMCTurbo
- Nov 12, 2005
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Wow 1 at a time,I used the one that goes on the drill and sharpen them on the track , biteharder sharpener for studs. Great product
DMCTurbo
- Nov 12, 2005
Ya this is a little tedious. So that said did you buy the professional version of the biteharder?Wow 1 at a time,I used the one that goes on the drill and sharpen them on the track , biteharder sharpener for studs. Great product
- 6K
