SnowBandit
- Jan 31, 2004
- Maine
- www.slednewengland.com
- 2009 Nytro xtx
Anyone know if you leave the kill switch down are you going to kill the battery on the Attak? I thought I read some where on here that if you did that to a Rx1 the battery would be drained?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You must either leave the kill switch down or put the key in the off position or you will drain the battery. You can't leave them both in the "on" position or the guage cluster and fuel pump will have power and it will drain the battery.
SnowBandit
- Jan 31, 2004
- Maine
- 2009 Nytro xtx
If I put the kill swith in the down position and the key is off with it drain the battery? I thought I read on here that someone did that and their battery went dead. Did they have the key on?
SledFreak
- Feb 7, 2005
- Ontario. Canada
No it will not.
- Apr 17, 2003
- Menno, SD
- Menno, SD
No it will not. As long as you have either the kill switch or the key in the "off" position it will not drain the battery.
SnowBandit
- Jan 31, 2004
- Maine
- 2009 Nytro xtx
Thanks for the info guys...
