kinger
Finally had to get towed yesterday I landed very hard after a jump and the sled just died. I got full power to everything and it cranks fine but won't fire. I have fuel pump priming and have fuel. Ideas? Thanks a lot guys.
btt as I am interested in what you find.
are all the wiring harness grounds good?
Dang ! Check spark .
kinger
Yes I went through all the wiring (well wiring that is accessible) and found nothing loose. The relays all look good, fuses are good. I am really baffled on this one. I know this sled in and better then anyone and dont have a clue.
My gut is saying I knocked something inside the stator loose as that would produce the same result but what are the chances of that!
It was definitly a top 5 hit, it felt like the sled bottomed out then went 2" past that. I thought I snapped the driveshaft at first but that was ok. Its odd I have power everywhere to everything like it should be. It will be awhile before I can pull the plugs and check for spark. I'll have to do some research on the ignition system. It doesnt even attempt to pop or start so its probably not getting spark.
Shiek
electrical
probably electrical , guess i would check if you are getting spark, wonder if something inside the kill switch or throttle block broke??
kinger
Where is the oil pressure sensor at? That will shut the sled down. Just uses one in the oil tank?
HighSpeedLowDrag
It will start and run for a few seconds with no oil pressure and shut down showing code 30 on the gauge, so it's not that.
Yeah must not be sparking! check up front on the ECU connections
You bottomed hard and wonder if you have a loose connection on a plug down there or over above the clutch plugs harness.check all relays too !
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
Any news as to what happened?
apex55
What about the wiring under the seat that goes to the fuel pump. With the impact you stated if you hit the seat hard enough.
kinger
I have the fuel pump and all gauges. I need to check for spark hopefully this week. I dropped it off at a shop for the first time ever. Hopefully they are good!
kinger
Great news on easy fix!
Hope you didn't miss out on too many ride days.
apex55
X2sideshowBob said:Great news on easy fix!
