Killed my sled....just cranks but won't fire FIXED
kinger
Clear Lake, IA
Website
www.piergenius.com
Finally had to get towed yesterday I landed very hard after a jump and the sled just died. I got full power to everything and it cranks fine but won't fire. I have fuel pump priming and have fuel. Ideas? Thanks a lot guys.
btt as I am interested in what you find.
are all the wiring harness grounds good?
Yes I went through all the wiring (well wiring that is accessible) and found nothing loose. The relays all look good, fuses are good. I am really baffled on this one. I know this sled in and better then anyone and dont have a clue.
My gut is saying I knocked something inside the stator loose as that would produce the same result but what are the chances of that!
It was definitly a top 5 hit, it felt like the sled bottomed out then went 2" past that. I thought I snapped the driveshaft at first but that was ok. Its odd I have power everywhere to everything like it should be. It will be awhile before I can pull the plugs and check for spark. I'll have to do some research on the ignition system. It doesnt even attempt to pop or start so its probably not getting spark.
It will start and run for a few seconds with no oil pressure and shut down showing code 30 on the gauge, so it's not that.
Yeah must not be sparking! check up front on the ECU connections
You bottomed hard and wonder if you have a loose connection on a plug down there or over above the clutch plugs harness.check all relays too !
FOUND IT! Knocked the fuel pump loose in the tank! haha Love easy fixes!
It was still wired and working but knocked it loose from the factory rig. (I have a non stock high flow pump and had to get "creative" to mount it)
